Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 32
    Mar 2020
    netherlands
    How much water does a outboard use?
    Hey! I was wondering, how much water does an outboard suck up at full throttle?
    Is it possible to calculate it? Im just curious.
    Is it: the capacity of all the chambers of the impeller × rpm?
    How large would the capacity of a 115hp 2 stroke be?
    Pekin, IL
    Damn dude, you must be bored.
    Rock
    Team Junk
    Quote Originally Posted by rock View Post
    Rock
    ...now thats funny...
  4. Likes keefallan, SS Minnow liked this post
    Just carry 4 barrels of good clean distilled water on your boat. And that should be enough for about 1 hour of full throttle
  6. Likes SS Minnow liked this post
    Dec 2017
    Lake Ashby, New Smyrna Beach FL
    I got 5 acres needing weeded...
  8. Likes SS Minnow, rgsauger, tnelsmn liked this post
    Jan 2015
    Quote Originally Posted by TraceF3 View Post
    You got 5 acres of what man?
    Dec 2017
    Hahahahahahahahhahahahahahahahhhahahhaaaaahhahahhhhh
    Quote Originally Posted by killerpirate View Post
    ...when you figure this out, what will you do with this capacity information?
    Aug 2009
    mpls,mn
    After the first case of beer I forgot what he was asking
    Aug 2009
    mpls,mn
    Sorry killer I just could not resist. How much wood could a wood chuck chuck if a wood chuck could chuck wood.
  14. #11
    Dec 2001
    Depends on which 115 l6.... or L4.....different h2o pumps.....Then the offset of pump housing. Then if ya have a restriction at the outlet......
  15. Likes racervboat liked this post
  16. #12
    8 Post(s)
    there is a MCM service bulletin for 1 drives, showing gear ratio and free flow volumes so for a 47-89984 you can work it out ish
  17. Likes keefallan liked this post
  18. #13
    Sep 2011
    maryland
    Killer, please dont be offended by the funny comment(s). It was all meant in fun. Its just an offbeat question. And truthfully, I cant answer that question for you. Please dont stop asking questions because of us. The same guys that make jokes will also be the same guys that give out great information when you need it.
  19. #14
    Its a very valid and good question, as I like a few others have often though about an external electrical water pump to feed the motors.
    one way to find out would be to put a drill on a drive shaft and see just how quick you empty a certain amount of water in say 3 minutes. BUT you have to remember its not the amount a motor actually uses, the adaptor chucks out any excess water that the motor dont need and dumps that into the mid section..... so what the motor consumes will be very different to how much the water pump pushes out... I would think you dump out more than you consume by a long way..
  20. Likes David - WI, keefallan liked this post
  21. #15
    May 2016
    keys
    I think once your up to speed, especially the speeds some of us see. The water pump is actually limiting flow. If it wasn't for idle time I doubt a water pump would be necessary. Someone better at math than me should be able to get close just by knowing the inlet area × pressure.
    Pressure would be a factor of speed. That should give an idea of how much water your passing, how much you actually need, would get a lot more complicated
  22. Likes David - WI liked this post
  1. salt water outboard
    By allboutspeed in forum Technical Discussion
    Last Post: 05-11-2009, 03:58 PM
  2. This would be fun!!!!! Shallow water drive outboard!
    By The Big Al in forum General Boating Discussion
    Last Post: 01-19-2007, 01:28 PM
  3. water pump in outboard
    By Carsen in forum Technical Discussion
    Last Post: 04-26-2003, 03:40 PM
