Results 1 to 5 of 5
10-27-2020, 11:07 PM #15000 RPM
- Feb 2005
- North Shores of Boston
- 515
Early Spring loaded drive shaft on 2.4 merc 200hp Lower unit
Hi I wanted to use an early style 2.4 ltr (spring loaded drive shaft) LOWER UNIT with later 2.5 ltr Powerhead.. Should I cut off the spring loaded pin - I once heard the early engines used to need the spring for Crankshaft end play - but the newer 2.5 ltr power head/crank do not need the spring because they installed thrust bearings and shims. What should I do.
Thanks
Jim
10-28-2020, 02:25 AM #2Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Don't cut it.... the pin is there to keep the gears meshed at slow speeds........the case will work under a 2.5...... but they are weak...... smaller pinion bearing........and shaft......
10-28-2020, 03:02 AM #3
it "loads" tha top bearing at all rpm.. only thing that keeps tha bearin' in place... has nothing ta do with crankshaft "end play" .. without it ya won't get very far from tha ramp..
10-28-2020, 01:20 PM #45000 RPM
- Feb 2005
- 515
Thank you for the replies !!
10-28-2020, 01:30 PM #5
yeah.. tha spring "pre load" was used ta keep bearing in place (bearing race is below bearing) before they changed to a "nut" on top of tha bearing (bearing race is on top of bearing..........
Merc 2.4 200hp Drive shaft play
By Primal 98 in forum Technical DiscussionReplies: 3Last Post: 08-08-2015, 12:43 PM -
CLE lower Unit Good case busted input shaft or drive shaft
By CRLmotorsports in forum Lower UnitsReplies: 14Last Post: 09-25-2014, 06:13 PM -
86 2.4 lower unit ,do i have to have the pin on top of drive shaft?
By camaro7081 in forum Technical DiscussionReplies: 5Last Post: 12-28-2005, 05:30 PM
