Results 1 to 14 of 14
Thread: Winterization
    Sep 2009
    Cleveland, Ohio
    Winterization
    Looking for thoughts on winterizing a 2018 300 XS OptiMaxx. The last two tanks of fuel have had stable in them. now for the winterization process , was wondering about the thoughts of just shutting the gas off and running motor out of fuel instead of using a separate tank with ethanol treatment in it. And running treatment through engine . Then just greasing fittings changing lower unit fluid and squirting oil into cylinders
    1986 cougar mtr 21
    2003 supra launch ssv
    Sep 2017
    ontario
    Supra - i was hoping to see what tech was brought up on the subject pertaining to the Opti - storage/ winterizing . I thought I had read here that Mercury does not support foghing oil into cylinders for storage .Hopefully someone chimes in on this and can help explain why or why not .
    I quickly did some snooping around and found a link that Mercury stated not to use fogging oil in EFI or Opti - it can create a problem with the injector tip. They did state that the use of the correct oil can be used in the cylinders for storage .
    Sep 2009
    Cleveland, Ohio
    Yes the manual states to use opti oil, 3 ml. Or so to squirt into each cylinder. My concern was the process of taking care of fuel system.
    1986 cougar mtr 21
    Sep 2017
    ontario
    Blake - from Injection Services may be a good guy to comment on fuel related -Opti stuff - he is inside this stuff more often and should be able to let us know what he knows on the subject .
    Stabilizer good, running out of fuel not. Those electric pumps don't last wrong when you run them out of fuel as needed for cooling and lubrication.
    Nov 2019
    Canada
    Fuel stabilizer and you are good to go. It wouldn't hurt to premix some 2-stroke oil in the fuel as well, keep everything lubricated.
    Serving Performance Boaters WORLDWIDE! Injectors, tunes, superchargers!
    PM us here or visit our website!
    http://injectorservice.com
    https://injectorservice.com/nizpro
    Forum thread about our services:
    https://www.screamandfly.com/showthread.php?347757-Canadian-Fuel-Injection-Service-North-America-Wide-Testing-Cleaning-Servicing!
  7. Likes Dave Strong liked this post
    Sep 2009
    Cleveland, Ohio
    I do have a few gallons of Klotz left over from our 260 motor I can add that to the fuel what ratio would you think. 75:1. Or 60 ish
    1986 cougar mtr 21
  9. #8
    Run a few minutes of avgas through it before shutting down for sleep
  10. #9
    Nov 2019
    Canada
    I would say 75 would be plenty. You just need a little to keep the pump and injectors lubed. Should help with cylinder walls as well.
  11. #10
    Sep 2009
    Cleveland, Ohio
    Thanks again, I will run a small tank of premix using 94 pump and a shot of aces.
    1986 cougar mtr 21
  12. #11
    Can't beat fresh avgas with premix, shelf life within the system and additives for cylinder.
  13. #12
    Western Pennsylvania
    Over the 10 yrs I had my 300xs I would treat the fuel before last run and run the tanks low. and follow the merc manual too.
    http://www.stvowners.com
    90 21Skater w/300xs - sold
    98 STV Euroski w/280 - sold
  14. #13
    Windsor, Ontario
    I put the boat away with the tank full of fuel with stabilizer. The tricky part for is fogging the 200XS. I use fogging oil and the plastic 'straw' is too short. Does anyone sell longer ones?
  15. #14
    Sep 2009
    Cleveland, Ohio
    Merc states to squirt opti oil in cylinders. Do not fog, I bought a syringe with hose to squirt in there
    1986 cougar mtr 21
  1. FL boy needing winterization input
    By CanyonDoug in forum General Boating Discussion
    Last Post: 11-14-2017, 11:32 PM
  2. Mercruiser winterization process
    By tgsearay in forum Technical Discussion
    Last Post: 09-13-2017, 04:56 PM
  3. Winterization Procedure for 225 Optimax
    By Just1More in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 03-11-2007, 02:38 PM
  4. Winterization Question 2.4
    By delawarerick in forum Technical Discussion
    Last Post: 10-17-2005, 05:09 PM
  5. Winterization care
    By jlittle in forum Technical Discussion
    Last Post: 10-02-2003, 02:06 PM
