Results 1 to 15 of 16
Thread: 141 rod mods
10-27-2020, 02:10 PM #1
141 rod mods
so when guys use the sps/arp 3/8ths head rod bolt in the 141 fishin rod , does the hole have to b drilled out and rethreaded along with clearance for head of bolt ?
Or is it just the head of bolt that needs mod and hole thread size the same?
10-27-2020, 02:18 PM #2
Just the clearance for the bolt head, threads the same
Merc 2.5 thanked for this post
10-27-2020, 02:39 PM #3
Grind ya a 3/8" (1/4" Drive) 12pt socket down until it fits.
Merc 2.5 thanked for this postDOC W, Tomanytoys liked this post
10-27-2020, 02:59 PM #4
10-27-2020, 03:11 PM #5
1 more question. How much diffrence in promarine non tty bolts (torque to 30 and no 90) vs the sps or arp torque to 30?
10-27-2020, 03:31 PM #6
10-27-2020, 03:32 PM #7
Michael J Giesler liked this post
10-27-2020, 03:36 PM #8
Pic ain’t worth a hoot, the grindin on the end is just a taper so that it leaves some meat on socket but gives a little extra clearance near cap
10-27-2020, 03:43 PM #9
Ok well im gonna go ahead and get the set for sale here and do whatever needs to use em
10-27-2020, 03:46 PM #10
Will the 5250 bolt work for the 141s?
10-27-2020, 03:54 PM #115000 RPM
- Oct 2004
- umatilla,FL
- 247
- 7
- 45
- 46
no its longer . yes it fits but the threads are not in correct contact because they stick out the bottom
10-27-2020, 03:55 PM #12
10-27-2020, 03:56 PM #135000 RPM
- Oct 2004
- umatilla,FL
- 247
- 7
- 45
- 46
RB2500-1 IF i remember right
10-27-2020, 04:01 PM #14
10-28-2020, 02:46 AM #15Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Clean threads real good...... red on bolt and hole......run in and out before tighting to #......Than the weak point is ya stick a piston and things break.... but the rod bolts are not the cause of carnage.
250 xs mods?
By moneyman509 in forum Technical DiscussionReplies: 0Last Post: 05-07-2011, 12:52 PM -
Mercury Tech: 250 efi mods
By blh1972 in forum Technical DiscussionReplies: 1Last Post: 10-27-2010, 10:23 PM -
02 250 XB Mods
By champit in forum Technical DiscussionReplies: 1Last Post: 02-09-2008, 11:23 PM -
2.4 Mods
By joey jamz in forum Technical DiscussionReplies: 9Last Post: 11-09-2004, 08:49 AM -
mods for 86 200
By obrien in forum Technical DiscussionReplies: 5Last Post: 09-05-2003, 06:33 PM
