Results 1 to 15 of 16
Thread: 141 rod mods
    Sep 2017
    Ashland city tn
    141 rod mods
    so when guys use the sps/arp 3/8ths head rod bolt in the 141 fishin rod , does the hole have to b drilled out and rethreaded along with clearance for head of bolt ?
    Or is it just the head of bolt that needs mod and hole thread size the same?
    May 2014
    Livingston, Louisiana
    Just the clearance for the bolt head, threads the same
  3. Thanks Merc 2.5 thanked for this post
    Sep 2007
    Pensacola FL
    Grind ya a 3/8" (1/4" Drive) 12pt socket down until it fits.
  5. Thanks Merc 2.5 thanked for this post
    Likes DOC W, Tomanytoys liked this post
    Sep 2017
    Ashland city tn
    Quote Originally Posted by tcrabtree View Post
    What do the sps or arp bolts torgue to? 30-40? Will socket hold it?
    Sep 2017
    Ashland city tn
    1 more question. How much diffrence in promarine non tty bolts (torque to 30 and no 90) vs the sps or arp torque to 30?
    May 2014
    I use a snap on 1/4 in drive socket with a little mode on tip. Holds up well. But even with that depending on rod, most still need a little clearancing to get the socket to fit nice and flush to get a good torque
    Sep 2007
    Pensacola FL
    Quote Originally Posted by Merc 2.5 View Post
    30Ft lbs. Itll hold fine, I build quite a few motors & been using the same socket for years.
  10. Likes Michael J Giesler liked this post
    May 2014
    Pic ain’t worth a hoot, the grindin on the end is just a taper so that it leaves some meat on socket but gives a little extra clearance near cap
    Sep 2017
    Ashland city tn
    Ok well im gonna go ahead and get the set for sale here and do whatever needs to use em
    Sep 2017
    Ashland city tn
    Will the 5250 bolt work for the 141s?
  14. #11
    umatilla,FL
    no its longer . yes it fits but the threads are not in correct contact because they stick out the bottom
    Sep 2017
    Ashland city tn
    Quote Originally Posted by DOC W View Post
    Well damn
  16. #13
    umatilla,FL
    RB2500-1 IF i remember right
  17. #14
    Sep 2017
    Ashland city tn
    Ya i see the blank is longer on bottom guide bolts. Thanks
  18. #15
    Dec 2001
    Clean threads real good...... red on bolt and hole......run in and out before tighting to #......Than the weak point is ya stick a piston and things break.... but the rod bolts are not the cause of carnage.
  1. 250 xs mods?
    By moneyman509 in forum Technical Discussion
    Last Post: 05-07-2011, 12:52 PM
  2. Mercury Tech: 250 efi mods
    By blh1972 in forum Technical Discussion
    Last Post: 10-27-2010, 10:23 PM
  3. 02 250 XB Mods
    By champit in forum Technical Discussion
    Last Post: 02-09-2008, 11:23 PM
  4. 2.4 Mods
    By joey jamz in forum Technical Discussion
    Last Post: 11-09-2004, 08:49 AM
  5. mods for 86 200
    By obrien in forum Technical Discussion
    Last Post: 09-05-2003, 06:33 PM
