Results 1 to 6 of 6
Thread: 21 Liberator 300XS trim stops
10-26-2020, 09:21 PM #1
10-27-2020, 09:40 AM #2
??? Just a guess here... Because it came with the motor?
10-27-2020, 12:25 PM #3
10-27-2020, 03:14 PM #45000 RPM
- Sep 2010
- arkansas
- 142
- 19
- 31
If the boat has a very good dial-in, sleeves are used around the pin to fine tune a repeatable top end trim setting. A one piece pin that goes all the way across is used instead of two bolts. Was common with no power trim.
The setup pictured is common to limit unneeded negative trim. So the motor isn't cycled trough a never used range.Last edited by tunnelfun; 10-27-2020 at 03:21 PM.
10-27-2020, 04:34 PM #5
that is what I first thought. neither of the past two owners were certain. on a prior tunnel, after airing out the tunnels and when the boat took a set, it liked just a little tuck(negative trim) to fly the best. maybe you're right on this one as well. I miss a little holeshot by not getting a full tuck...
10-27-2020, 11:47 PM #6
They come on the offshore motors. Just take them out
Boat Delivery available
Things owned. NOTHING!!
21 Liberator w/ 300XS
By wasvette in forum Hulls larger than 20'Replies: 29Last Post: 01-04-2018, 06:49 PM -
21 Liberator with 300xs
By Ospreyproduction in forum Hulls larger than 20'Replies: 12Last Post: 06-04-2017, 08:49 AM -
Liberator 21, 300XS w/ SM & 1.75--help pls
By wasvette in forum Props, Setup, and RiggingReplies: 16Last Post: 06-20-2016, 06:53 AM
