Results 1 to 6 of 6
    Jun 2017
    Connecticut
    200 carb 2.5l stuck at 3000 RPM
    So first time this happened was about two months ago on a colder moister morning where the engine would really just not go past 2900 to 3100 rpm. Other than that seemed smooth and fine. After a few minutes problem went away no issues for two months maybe 15 trips.
    This weekend same thing colder moister morning but it was stuck for maybe 2 hours or so at 3000 rpm then corrected and was good for the day.
    Seems like the high speed stator coils aren't working when its cold or Foggy? anyone have this happen before and know how to diagnose or know if its the stator or switch boxes?
    I tightened all the stator connections to be sure and that didn't solve it that morning when it wasn't working for 2 hours
    Thanks!
    Sep 2017
    Ashland city tn
    Need try get meter and test few things if u got a manual
    Jun 2017
    Connecticut
    Thanks I got the manual and DVA. Next time it acts up Ill find out if the stator isnt producing to spec. was just wondering if someone knew something like: oh yea moisture is shorting out at location x, or cold is causing an open at Z.
    Sep 2017
    Ashland city tn
    Your gonna find it on stator more than likely on high side , u said its not really missin? If not missing prob not the switchboxes
    Jun 2017
    Connecticut
    Yea smooth as can be. And it either stops at 3000 rpm, but then once it clears that point it goes all the way to 5800 rpm and works for the rest of the day.
    Sep 2017
    Ashland city tn
    Did it just start this?
  1. 1990 2.4 carb mod-vp motor powerheads (2) / $3000 each
    By ONE-A-DAY in forum Outboard Engines
    Last Post: 07-11-2017, 12:45 PM
  2. 93 2.5 carb 150 3000$ complete
    By 265mercman in forum Outboard Engines
    Last Post: 08-06-2016, 11:37 PM
  3. Stripped jet stuck in carb, now what?
    By honkbert in forum Technical Discussion
    Last Post: 07-18-2016, 11:50 PM
  4. '94 200 EFI Mariner stuck @ 3000 RPM
    By 3Nails in forum Technical Discussion
    Last Post: 03-04-2008, 11:58 PM
  5. 1990 Johnson stuck @ 3000 rpm
    By Streamin Along in forum Technical Discussion
    Last Post: 03-18-2005, 09:36 AM
