Results 1 to 6 of 6
Thread: 200 carb 2.5l stuck at 3000 RPM
10-26-2020, 05:58 PM #15000 RPM
- Jun 2017
- Connecticut
- 263
- 38
- 19
- 33
- 21
So first time this happened was about two months ago on a colder moister morning where the engine would really just not go past 2900 to 3100 rpm. Other than that seemed smooth and fine. After a few minutes problem went away no issues for two months maybe 15 trips.
This weekend same thing colder moister morning but it was stuck for maybe 2 hours or so at 3000 rpm then corrected and was good for the day.
Seems like the high speed stator coils aren't working when its cold or Foggy? anyone have this happen before and know how to diagnose or know if its the stator or switch boxes?
I tightened all the stator connections to be sure and that didn't solve it that morning when it wasn't working for 2 hours
Thanks!
10-26-2020, 07:05 PM #2
Need try get meter and test few things if u got a manual
10-26-2020, 09:52 PM #35000 RPM
- Jun 2017
- Connecticut
- 263
- 38
- 19
- 33
- 21
Thanks I got the manual and DVA. Next time it acts up Ill find out if the stator isnt producing to spec. was just wondering if someone knew something like: oh yea moisture is shorting out at location x, or cold is causing an open at Z.
10-27-2020, 06:17 AM #4
Your gonna find it on stator more than likely on high side , u said its not really missin? If not missing prob not the switchboxes
10-27-2020, 07:18 AM #55000 RPM
- Jun 2017
- Connecticut
- 263
- 38
- 19
- 33
- 21
Yea smooth as can be. And it either stops at 3000 rpm, but then once it clears that point it goes all the way to 5800 rpm and works for the rest of the day.
10-27-2020, 01:43 PM #6
Did it just start this?
1990 2.4 carb mod-vp motor powerheads (2) / $3000 each
By ONE-A-DAY in forum Outboard EnginesReplies: 8Last Post: 07-11-2017, 12:45 PM -
93 2.5 carb 150 3000$ complete
By 265mercman in forum Outboard EnginesReplies: 0Last Post: 08-06-2016, 11:37 PM -
Stripped jet stuck in carb, now what?
By honkbert in forum Technical DiscussionReplies: 8Last Post: 07-18-2016, 11:50 PM -
'94 200 EFI Mariner stuck @ 3000 RPM
By 3Nails in forum Technical DiscussionReplies: 5Last Post: 03-04-2008, 11:58 PM -
1990 Johnson stuck @ 3000 rpm
By Streamin Along in forum Technical DiscussionReplies: 6Last Post: 03-18-2005, 09:36 AM
