Results 1 to 15 of 43
Thread: Mercury Mark 15
10-26-2020, 03:56 PM #1
Mercury Mark 15
I have had this motor for many years but just now getting around to it. I am guessing middle 50s serial #717225. Everything looks original, as far as I know, and crankcase still has lead seal. Crankshaft turns easily and motor has compression. Cowling has no cracks or missing parts. Never seen fuel hook up like this so I'll be needing one of those and I am sure I'll have a few questions along the way. Simplicity is astounding.
RockTeam Junk
10-26-2020, 10:21 PM #2
The pressurized tank...I have a very nice specimen..or do the conversion to the pulse pump. Anyhoo good to see this. I love 50s outboards
https://photos.app.goo.gl/k6mwuE2P8D6sGS689
rock thanked for this post
10-27-2020, 10:59 AM #35000 RPM
- Feb 2004
- North Tonawanda, NY
- 686
Hopefully you can find a tank in the back of your garage that came with the motor- the old pressure tanks are hard to find in working order along with the conversion parts. Even back in the early '60s we wouldn't touch a used Mark 15/20 Merc unless it came with a working tank and hose assembly. I chose to stick with my gravity feed "tank on powerhead" Merc KG4 and KG7 Hurricanes until I could scrounge the bucks for a used Mark 25 with a real fuel pump. I looked in my boneyard to see if I had a tank I could give you- but all I found was a few parts from an old OMC pressure tank. I have a restored KG4 in the basement that I bought as parts in a box back in the early '80s. Runs good but smokes like crazy on 24:1 oil compared to motors running at 50:1 mix.
Doug
10-27-2020, 12:31 PM #4
Pressurized fuel system eh. At least that answers one question.
RockTeam Junk
10-27-2020, 03:31 PM #5
I come across the merc pressure tanks pretty often in large antique malls. Just found another omc tank in PA to add to my stockpile. Ill grab the next one I find and let you know
10-27-2020, 04:04 PM #6
I will pick mine up from the up north shop tomorrow. That is the "cruiser" mark 15. Kind of a rare little motor.
10-28-2020, 08:08 AM #7Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
You can use any....... newer......Merc pump from a 1 hose motor......The screw patten is the same....
10-28-2020, 08:20 AM #8
Well I spun motor and had spark on one hole. Pulled the flywheel to clean points and after doing that I have no spark. Ordered new condensers as everything else looks to be ok.
RockTeam Junk
10-28-2020, 11:36 PM #9Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Just a bit of lint..........a wire touchin the Grnd........The cam is on the shaft on that one rite? I used to do the Mags for the 44 motors.....play with the point setting tilll I had a spark that would jump 5/16 at the coil....at hand speed. I have.....a 4 cly Merc drone motor.... the mag comes off and is not attched to the motor....scliilar Like what was on KG7s..... only bigger.....can't get spark out of it........gotta play w/ it........
11-02-2020, 06:19 AM #105000 RPM
- Nov 2001
- upstate newyork
- 441
Anyone have any of the old style siamese hose for the tanks. I have a 20H with a three gallon pressure tank. The hose is shot.
Capt.Insane-o liked this post
11-02-2020, 01:14 PM #11
Beautiful motor! I'm glad you saved another one from the scrap pile.
www.InjectorService.com
Call/Text - 204-326-0390
11-02-2020, 06:03 PM #12
11-04-2020, 01:38 PM #13
Well it fired. Now it's time to address the fuel system but first I am going to undo lower and see what I can see.
RockTeam Junk
11-05-2020, 08:22 AM #14
Pulled lower and it's not good. Need to make a couple tools for disassembly or find a complete lower.
RockTeam Junk
11-05-2020, 03:43 PM #15Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Best off....at least what I have seen with old salty motors is drill the cover plate........ I might have some NOS ones......I might have acess to the tools....
Mercury Tech: Mercury Mark 6
By johnboy 88 vegas in forum Technical DiscussionReplies: 6Last Post: 11-30-2012, 06:46 AM -
Mercury Mark 58A Picture?
By Boat Restorer's Daughter in forum Outboard and Racing HistoryReplies: 1Last Post: 11-23-2007, 04:45 PM -
Royal Mercury Mark 78
By largecar91 in forum Outboard and Racing HistoryReplies: 4Last Post: 03-20-2005, 02:59 PM -
Mercury Mark 55 LE lube
By Mark Mercury in forum Technical DiscussionReplies: 3Last Post: 07-14-2004, 06:37 AM -
mark up on mercury outboards
By JIMKID motorsports in forum General Boating DiscussionReplies: 14Last Post: 03-09-2003, 10:19 AM
