Results 46 to 58 of 58
Thread: FF vs EFI vs what the hell ?
10-30-2020, 10:15 AM #46The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
10-30-2020, 10:20 AM #47The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
tnelsmn liked this post
10-30-2020, 10:42 AM #48
Bunny denial
nitro_rat liked this post
10-30-2020, 11:37 AM #49The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
10-30-2020, 12:32 PM #506000 RPM
- May 2001
- Madison, WI
- 1,147
- 253
- 39
- 498
- 198
From a service manual and technical perspective...I agree on the DD proposal.This is an brilliant suggestion.
I suggest an urgent internal change order to make the identity change. Then follow up with a service bulletin with detailed close up color pictures to clarify.
10-31-2020, 07:17 AM #515000 RPM
- Mar 2018
- NJ
- 196
- 10
I am just catching up with this conversation about block Lettering. I had purchased a 245 about 6 months ago that has- ll -stamped on the block,is this LL. Thank you
11-04-2020, 03:53 PM #52
How did I miss those bunny pictures! Hahahaha!
www.InjectorService.com
Call/Text - 204-326-0390
11-05-2020, 07:11 AM #53
11-05-2020, 04:53 PM #545000 RPM
- Mar 2018
- NJ
- 196
- 10
There is these numbers stamped above the 2 straight lines-9272673-,these are factory stamps there is no grinding to the surface. Last thing it is also a big bearing,don't know if any of this helps. Thank you
11-05-2020, 05:37 PM #55
lost me with those numbers.. sure someone may be able ta track 'em down maybe?.. there were no 245/carb motors built from merc with tha "big bearing".. it has a "big journal" (1 1/2") top main but not a "big bearing" (260's, 280's, drag) as to what most folks relate to.. does it have bleed bibs on tha cylinders?.. last 245 was '95 i think..
have you found tha build date?
11-05-2020, 06:44 PM #565000 RPM
- Mar 2018
- NJ
- 196
- 10
Thank You for the Help--It does have the bleed bibs, 1 head is stamped 95 other is stamped 92,it does have a steel sleeve. Thank you
11-12-2020, 09:44 PM #57
11-13-2020, 07:33 AM #585000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
I'm wondering if the stamp directly relates to the porting the block got as well as other characteristics already mentioned.
what the hell?
By PARKER RABE in forum General Boating DiscussionReplies: 69Last Post: 05-09-2010, 07:25 PM -
What the hell?
By wide_open in forum General Boating DiscussionReplies: 3Last Post: 11-29-2006, 09:22 PM -
What the Hell????
By gdfatha in forum General Boating DiscussionReplies: 2Last Post: 01-09-2006, 05:58 PM -
Hell!
By Alan Power in forum The Scream And Fly LoungeReplies: 7Last Post: 03-22-2005, 03:45 AM -
What the hell????
By gdfatha in forum Racer's HangoutReplies: 13Last Post: 11-08-2004, 10:11 PM
