Results 1 to 15 of 21
Thread: Really overpowering my boat
10-25-2020, 05:05 PM #15000 RPM
- Mar 2020
- netherlands
- 163
- 14
Hello, im thinking of really overpowering my boat. its rated for 90 hp, but i want to attach a 150-175-200 v6 on it. Because of the power and weight i am afraid my transom will give in. But i thought, if i use a tension strap and attach a couple of eyenuts on the upper engine bolts, and connect 1 end of the strap to the transom, and the other end to the skipole in the center (see photo), and really really tighten the strap, (it functions as a stringer) the engine will not pull only on the transom, but also on the skipole. This way the stress on the transom is reduced.
My question, will a tension strap work? Or doesnt it work well enough to hold the power of the v6. Or maybe i need steel threads and a tightener in between?
10-25-2020, 05:12 PM #2
If your transom isn’t strong enough and NEEDs a strap to the ski pole, then this is not a good idea.
'95 STV "The Blue Goose"
10-25-2020, 05:17 PM #3Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
This is awesome.
Post a well lighted clear picture of the bilge area and transom, also the splash well.
Missed a good one in Denmark
https://www.bing.com/images/search?v...=0&vt=4&sim=11
And for those craving the FORCE in FL
A peach!
https://www.shoppok.com/treasure/a,2...ne----1000.htmLast edited by FMP; 10-25-2020 at 05:45 PM.
10-25-2020, 06:04 PM #4
Straps stretch.. plane and simple.
In other words NO a strap will NOT work
SS Minnow liked this post
10-25-2020, 06:17 PM #5Screaming And Flying!
- Dec 2001
- 9,503
- 270
- 191
- 1975
Depends......on how ya transom is.......going from a 90 tooo 150 is YA......Beef it up and have funn....Life is short.
10-25-2020, 06:24 PM #6Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Absolutely, assess what it requires and make it safe.
10-25-2020, 06:25 PM #75000 RPM
- Oct 2011
- Ontario
- 369
- 32
- 46
- 335
- 134
- 7 Post(s)
If your boat is sound, than I would do it and have a blast.
I've been doing this my hole life lol.
We even put a 9.9 on a canoe when I was a young teen
10-25-2020, 06:29 PM #8Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
25 on a 10' lol
keefallan liked this post
10-25-2020, 06:47 PM #9
I put a hopped up 70hp 3 cylinder OMC on a 15' aluminum jon boat rated for 25hp. Built my own tiller for the motor. You could only hold it to about 42 mph in a short burst, sure was fun though...
Josh Peterson
10-25-2020, 06:48 PM #10Screaming And Flying!
- Dec 2001
- 9,503
- 270
- 191
- 1975
10-25-2020, 06:59 PM #11Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Needed to weld the bottom back together on the 10' wasn't that long ago LMAO
10-25-2020, 07:11 PM #12Banned
- Jan 2015
- Wisconsin
- 2,331
- 458
- 343
- 6429
- 5147
- 4 Post(s)
What he said ^^^^^^^
You can beef up the transom or add a knee or two with a stringer(s). But if the transom is not strong enough without straps or brackets, then do not do it.
ETA Not sure how the laws are over there, but some places on this side of the pond, if you knowingly overpower a boat and somebody gets hurt, you might be facing criminal charges. Just something to think about.Last edited by SS Minnow; 10-25-2020 at 07:15 PM.
10-26-2020, 03:14 AM #135000 RPM
- Mar 2020
- netherlands
- 163
- 14
Thanks! But the straps will add a lot of strength right? The skipole is very solid and the straps are rated for 1000kg
10-26-2020, 05:41 AM #14
So this was my 1st way over powerd. It measured 14'9 and rated for 105. I had 2 115s a 140 , 2 150s, and 2 200s. My transom was pretty solid , as in no cracks no where and didn't flex , with 115. I put all thread thru transom into the back deck along with thick aluminum plates , the 150 did good and was still hard to drive at wot , when 200 went on it really didn't go no faster at wot because of the boat , but it would get to that speed faster the stern wanted to pass the front. I ran that boat for yrs like that. But the transom I started with was in decent shape
Sry biut chity picLast edited by Merc 2.5; 10-26-2020 at 05:43 AM.
rgsauger liked this post
10-26-2020, 02:00 PM #155000 RPM
- Mar 2020
- netherlands
- 163
- 14
#1 boat gets beached, #2 'pro' pulls boat off beach, #3 boat rolls and sinks
By appsyscons in forum General Boating DiscussionReplies: 32Last Post: 06-17-2017, 04:01 PM -
overpowering concerns
By reacler in forum General Boating DiscussionReplies: 25Last Post: 07-10-2012, 02:16 PM -
actual overpowering laws from state to state
By rock in forum General Boating DiscussionReplies: 12Last Post: 03-25-2010, 08:12 PM -
Need help on how not to kill myself by overpowering
By overboardmarine in forum Technical DiscussionReplies: 7Last Post: 01-24-2008, 11:59 AM -
Overpowering your hull
By Lockjaw in forum The Scream And Fly LoungeReplies: 137Last Post: 05-27-2006, 06:46 AM
