Results 1 to 6 of 6
10-25-2020, 10:09 AM #15000 RPM
- Sep 2017
- ontario
- 716
- 67
- 43
- 73
- 171
280 coils and ECU driver blown on #6
So recently found my ECU was not fireing #6 switched coil leads and no change so suspected wireing or ECU . Inspected wireing and found nothing so sent off ECU . Problem found #6 driver was bad - luckily driver had not heated up bad and had not melted into board and was able to fix . Thanks to Dan at Simon's Performance and tech . They are still fixing ECUs and glad for that . Great company excellent communication and skillsets .
Repair was made and the conversation was about the coils - bad coil on six and at minamum replace one coil but better solution was to replace them all . So what do most on the forum do - replace one or all . #2 I have read a couple threads on coil problems , what are the facts on that story .
Just to make everyone aware when I hooked this up to DDT - i saw a history of misfires and a conversation on here about that was it's usual to see misfire history on 280 especially in long idle zones - the DDT history was cleared and did not show a misfire even when #6 was not firing with the ECM driver 6 was blown . I was surprised the DDT did not show that .
10-31-2020, 10:47 AM #2
Glad to hear you got your problems sorted out Kelly!
www.InjectorService.com
Call/Text - 204-326-0390
11-03-2020, 08:04 AM #35000 RPM
- Sep 2017
- ontario
- 716
- 67
- 43
- 73
- 171
Thanks Blake - appreciate the reply . I was hoping to get a healthy discussion on why the DDT did not show the #6 not firing in the end. I can only assume that the DDT will only show if the ECM is healthy and telling the coil to fire .
Then there was the question on the coil packs - Dan from Simon's Performance tech had stated it's the coil that took down the ECM - replace one if not the entire pack of them . I was trying to get a good thorough discussion on the matter so that the next guy that comes looking for an answer . This power was a 2004 280 ROS box Any input appreciated .
11-03-2020, 10:18 AM #4
Ill be honest Kelly, I'm not your guy to answer that. I've used CDS and CDS G3 but never had to use the DDT tool. That being said, I would go ahead and replace all the coils as cheap insurance.
11-06-2020, 07:10 AM #55000 RPM
- Sep 2017
- ontario
- 716
- 67
- 43
- 73
- 171
Thanks for the replies Blake - allot here are very preoccupied with the election at the moment - rightfully so.
rgsauger liked this post
12-02-2020, 01:46 AM #6Junior Member
- Jan 2005
- Wellington New Zealand
- 21
Hi
Coming from a Auto Electricians point of view I would replace all 6 as they are the same age
Time and time again I hear stories of replacing one coil then another problem with another coil and then it goes on
It is not uncommon for a coil to damage a ECM or igniter
I did have a coil not firing once on a 280 after a freshen up and it was a bad plug at the ECM ( Just saying )
Cheers
JohnNothing starts the day better than the sound of an open exhast Merc at full noise and smell of aviation fuel
70's driver
By Marty Olsen in forum General Boating DiscussionReplies: 0Last Post: 03-14-2014, 10:35 AM -
which coils have more output-optimax or gm ls series coils?
By mrcrsr in forum Technical DiscussionReplies: 189Last Post: 08-03-2011, 08:22 AM -
blown alky hydro/ blown alky flat
By amatosanger in forum Jet Boats, V-Drives and Stern DrivesReplies: 12Last Post: 11-05-2007, 04:13 PM -
Cab driver
By JOHNNYGUN in forum The Scream And Fly LoungeReplies: 0Last Post: 01-16-2004, 10:04 AM
