Results 1 to 6 of 6
    Sep 2017
    ontario
    280 coils and ECU driver blown on #6
    So recently found my ECU was not fireing #6 switched coil leads and no change so suspected wireing or ECU . Inspected wireing and found nothing so sent off ECU . Problem found #6 driver was bad - luckily driver had not heated up bad and had not melted into board and was able to fix . Thanks to Dan at Simon's Performance and tech . They are still fixing ECUs and glad for that . Great company excellent communication and skillsets .
    Repair was made and the conversation was about the coils - bad coil on six and at minamum replace one coil but better solution was to replace them all . So what do most on the forum do - replace one or all . #2 I have read a couple threads on coil problems , what are the facts on that story .
    Just to make everyone aware when I hooked this up to DDT - i saw a history of misfires and a conversation on here about that was it's usual to see misfire history on 280 especially in long idle zones - the DDT history was cleared and did not show a misfire even when #6 was not firing with the ECM driver 6 was blown . I was surprised the DDT did not show that .
    Nov 2019
    Canada
    Glad to hear you got your problems sorted out Kelly!
    www.InjectorService.com
    Call/Text - 204-326-0390
    Sep 2017
    ontario
    Thanks Blake - appreciate the reply . I was hoping to get a healthy discussion on why the DDT did not show the #6 not firing in the end. I can only assume that the DDT will only show if the ECM is healthy and telling the coil to fire .
    Then there was the question on the coil packs - Dan from Simon's Performance tech had stated it's the coil that took down the ECM - replace one if not the entire pack of them . I was trying to get a good thorough discussion on the matter so that the next guy that comes looking for an answer . This power was a 2004 280 ROS box Any input appreciated .
    Nov 2019
    Canada
    Ill be honest Kelly, I'm not your guy to answer that. I've used CDS and CDS G3 but never had to use the DDT tool. That being said, I would go ahead and replace all the coils as cheap insurance.
    Sep 2017
    ontario
    Thanks for the replies Blake - allot here are very preoccupied with the election at the moment - rightfully so.
  6. Likes rgsauger liked this post
    Jan 2005
    Wellington New Zealand
    Hi
    Coming from a Auto Electricians point of view I would replace all 6 as they are the same age
    Time and time again I hear stories of replacing one coil then another problem with another coil and then it goes on
    It is not uncommon for a coil to damage a ECM or igniter
    I did have a coil not firing once on a 280 after a freshen up and it was a bad plug at the ECM ( Just saying )
    Cheers
    John
    Nothing starts the day better than the sound of an open exhast Merc at full noise and smell of aviation fuel
  1. 70's driver
    By Marty Olsen in forum General Boating Discussion
    Last Post: 03-14-2014, 10:35 AM
  2. which coils have more output-optimax or gm ls series coils?
    By mrcrsr in forum Technical Discussion
    Last Post: 08-03-2011, 08:22 AM
  3. blown alky hydro/ blown alky flat
    By amatosanger in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 11-05-2007, 04:13 PM
  4. Cab driver
    By JOHNNYGUN in forum The Scream And Fly Lounge
    Last Post: 01-16-2004, 10:04 AM
