Results 16 to 22 of 22
Thread: Merc poppet valve issues
10-29-2020, 07:06 PM #165000 RPM
- Feb 2004
- Tarpon Springs, Florida
- 123
- 7
11-03-2020, 06:57 PM #17New Member
- Aug 2020
- Mississippi
I got lazy and tried to replace my poppet valve without taking the lower cowling off. The gaskets shifted when putting it back together because it was so tight in there and leaked. Got some new gaskets and learned my lesson.
11-03-2020, 07:34 PM #18Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
The good thing is you found it!!!!! and the situation is welded in your though process you wont do it again
11-04-2020, 12:04 PM #19The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
11-05-2020, 11:15 AM #20Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
I'm guessing aftermarket parts supplier?
11-05-2020, 11:29 PM #21
Wee a makin fo U 1,000,000 poppit a bowelb ... unibersal a fit aal ouwbor mo a ttor .. goo prise .. 3 cent fo a peece ... U buy a now !
XstreamVking, Dave Strong liked this post
11-06-2020, 10:57 AM #22
My Pro Max had strange things going on with water press dropping of at 10-12psi and running warm when cruising at that rpm from new. Merc blamed it on hull shape and motor height, I called BS. #9 is a plastic washer that is flat from new but after time from heat will dish. Made a washer same dimensions as the new one out of aluminum problem solved.
Poppet valve/relief valve issues 1978 2.4l Merc
By rujr in forum Technical DiscussionReplies: 2Last Post: 06-24-2013, 08:21 PM -
1988 200 merc poppet valve
By 585eric in forum Technical DiscussionReplies: 3Last Post: 06-27-2009, 07:28 PM -
Merc Poppet Valve Discharge Line
By bm1961 in forum Technical DiscussionReplies: 9Last Post: 04-26-2007, 10:35 AM -
Poppet valve question (2.4L 175 merc)
By fofiveoh in forum Technical DiscussionReplies: 3Last Post: 07-22-2004, 06:36 AM
