Results 1 to 2 of 2
10-25-2020, 07:19 AM #1
2005 50hp 2 cycle winterizing help please
Is it self draining like mercury's or do I need to run the pink stuff through?
I've going to the normal stuff, gear oil change, treated fuel
thanksCheckmate 2002 Convincor 270 496 MAG-HO
90 21Skater w/300xs - sold
98 STV Euroski w/280 - sold
10-25-2020, 08:13 AM #25000 RPM
- Oct 2011
- Ontario
- 370
- 32
- 46
- 336
- 134
- 7 Post(s)
That's right. It is self draining, no pink stuff required. If you want to go to the next step, you can fog the motor in. Fogging spray can be bought anywhere they sale gas and oil additives. Take the plastic intake cover off, start the engine in the water or with ear muffs, disconnect the gas line while motor is running and start spraying into all of the carbs, one at a time. the amount you use is up to you. I have friends who will empty a can on each motor they do but I'm more conservative.
Hope this helps
Winterizing? How about DE-winterizing!!!
By home made tunnel in forum General Boating DiscussionReplies: 5Last Post: 04-16-2017, 09:45 AM -
Repower Boston Whaler 255 - single or twin, 2-cycle or 4-cycle?
By Skytour in forum Technical DiscussionReplies: 19Last Post: 05-06-2010, 08:47 AM -
Mercury Tech: OMG while winterizing!!
By baja85 in forum Technical DiscussionReplies: 5Last Post: 10-07-2008, 07:36 PM -
2-cycle VS 4-cycle lower units -OBs
By Techno in forum Technical DiscussionReplies: 3Last Post: 09-26-2007, 08:40 AM -
2.5 260 efi winterizing
By EddyT in forum Technical DiscussionReplies: 3Last Post: 10-20-2004, 06:03 PM
