Page 3 of 3 FirstFirst 1 2 3
Results 31 to 36 of 36
  1. #31
    Maybe power was asking about a pic from the inside of the tuner up through the adapter into the block and adapter through to the block?
    Power, Racer. About that water passage log right where it's stupid. How's the fix to plumb external around it and cut and weld plug it up ?
    Build up the bad dead spots ceramic aluminum shape and smooth, get a nice turn through the "S" bubble - block- adapt .
  2. #32
    8 Post(s)
    Bill Ghor posted long time ago, said cut that out and weld it up.
    How about use 235 adapter and mod the exhaust to go straight down KR style...
  3. Thanks FMP thanked for this post
  4. #33
    Sep 2011
    maryland
    Will cut/weld affect cooling in any way?
    KR style......got any pics? I honestly know nothing of the KR motors.......
    I wish I did at this juncture.....time to learn.
  5. #34
    8 Post(s)
    KR 15, when doing big revs its all about getting the exhaust out
    Attached Thumbnails Attached Thumbnails KR 15 exhaust.jpg   KR15M Page28.pdf
  6. Thanks keefallan thanked for this post
  7. #35
    It'll cruise better , part throttle.
  8. #36
    Keef ... Don't try to reinvent the wheel. Do your best to get your line of sight straightened out. Nothing sharp .. tear drop , bullet nose , will be the most bang for the buck .. time spent. A lot of the other stuff will get you bogged down in .. "tech lock" .. Don't axe me how I know ...
    Long term .. get everything you can projects .. mill out junk that's in the way .. build it back with weld .. machine everybody flat . Air and kinked up conduit's have never been good for power. Reduced head 12 point, washer with type bolts will get them out of the air stream.
    If you want to feed the heads cold water .. take it before it gets to the block if you can . pushlock fittings and air brake hose will work fine ..
    if you find yourself bandsawing blocks in half to see how thick casting are .. and what can be done to straighten flow path's out ... you know your out on the edge .. LOL
  9. Likes keefallan liked this post
  1. OMC Tech: Crossflow build
    By Fastbass88 in forum Technical Discussion
    Last Post: 07-14-2020, 11:20 PM
  2. Mercury Tech: 225 2.5 Promax Build. Starting with a new 2015 block - tell me your secrets!
    By Fullthrottleguy in forum Technical Discussion
    Last Post: 02-27-2020, 08:50 AM
  3. Starting another new 21 Liberator build
    By WILDMAN in forum General Boating Discussion
    Last Post: 01-24-2013, 10:30 PM
  4. Finally a flushing kit that cost 20$ to build for CLE LU
    By dompie99 in forum Technical Discussion
    Last Post: 10-15-2006, 10:33 PM
  5. Finally! Pics of the 2.6XP Build Up
    By B.Leonard in forum Technical Discussion
    Last Post: 08-28-2002, 08:10 AM
