Results 1 to 11 of 11
    Jan 2010
    Rotorua, NZ
    What cause this 2.4 to grenade?
    Well, the day has finally come when my old 2.4 laser **** the bed... Was running great across the lake at about 6k rpm, lost a bit of power for about 2 seconds, got real loud for about another 2 seconds then seized...
    What do you reckon caused it? Does it look to you like the whole motor's been lean? Wasn't any piston dust on the #5 spark plug, looks like bearing cage material in the that rubbish tho?
    Looking for a good powerhead in north island NZ if any of you are down this way!
    Cheers
    Gene
ID:	475711Click image for larger version.
ID:	475712Click image for larger version.
ID:	475713Click image for larger version.
ID:	475714Click image for larger version.
ID:	475715Click image for larger version.
ID:	475716Click image for larger version.
    Injector failure
    Jan 2010
    Rotorua, NZ
    Injector failure
    Hmm, probably pretty likely I guess
    TN
    regular gas?
    double firing switchbox?
    lean?
    timing too high?
    Mar 2010
    houston, tx
    Injector failure
    Or injector driver in the ecu. I had one do that and sounded exacrl as he described.
    Jan 2010
    Rotorua, NZ
    I have wondered about the quality of the "98" gas at the station I've been using lately, could have got a bad batch I guess... Switchboxes are only a couple years old but ya never know. I haven't touched the mixture or timing in the last couple years.
    It's got a brucato ACU so don't imagine it's the cause - it'll go back to brucato for a checkup before being re-used/sold so we'll see
    Jan 2010
    Rotorua, NZ
    Has anyone got any feedback on this mariner 2.5 150 EFI? it's a '99 apparently... would it actually be a bit lazy/sluggish compared to my old 220 laser or probably not given the much newer generation etc? Thanks for any advice
ID:	475786Click image for larger version.
ID:	475787Click image for larger version.
    Sep 2017
    Ashland city tn
    I hear the 220 laser ran pretty gud. Don't really c a 150 runnin with it but the 2.5 b easier to mod with steel sleeves
    Jan 2010
    Rotorua, NZ
    Quote Originally Posted by Merc 2.5 View Post
    Cheers, think I'll keep an eye out for a 2.5 200 then
    Jun 2001
    Cromwell. NEW ZEALAND
    I have a 2.4 200 block. It needs 1 cylinder sleeved( I have the sleeve) I also have rods and pistons. Im in Cromwell
    Popey
    Jan 2010
    Rotorua, NZ
    Quote Originally Posted by Steve Pope View Post
    Cheers Steve, I'm really wanting to get myself a complete 2.5 that'll basically bolt on though (will do reeds, premix, usual stuff of course)
  1. Navy SEAL falls on grenade to save comrades
    By jeffbare in forum The Scream And Fly Lounge
    Last Post: 10-18-2006, 12:50 PM
  2. No Oil = Floating Grenade
    By BackwoodsMotorsports in forum General Boating Discussion
    Last Post: 05-23-2005, 03:07 PM
