Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 46 to 60 of 72
  1. #46
    Nov 2019
    Canada
    Wow this thread is worth a good laugh!
    www.InjectorService.com
    Call/Text - 204-326-0390
  2. Likes XstreamVking liked this post
  3. #47
    Aug 2006
    GA
    I have owned both & liked them as equal.
  4. Likes Merc 2.5, robert jordan liked this post
  5. #48
    May 2016
    keys
    EE blocks matter
  6. Likes TEXAS20225, FUJIMO, Aaronhl, mach351, rgsauger liked this post
  7. #49
    Jul 2002
    FT WORTH, TEXAS
    if you could James Perry on here to splain all this you would know the 200 ff block takes the exact same sleeve as a 225 promax minus rod slots and some very large champhers or explain the fact that 260 ports are not as big as you might think he has installed 100's of sleeves for me thru the years he knows his stuff
  8. Likes LakeFever, Capt.Insane-o liked this post
  9. #50
    Sep 2017
    Ashland city tn
    Quote Originally Posted by TEXAS20225 View Post
    I was gonna go into that but didn't wanna stir the pot, the fact the 260 has a very very small intake port is the the ticket, thats y we don't mess with opening intakes
  10. #51
    Mar 2017
    Miami, FL
    I fell into the FF fascination. Had about 3-4 of them. Now I have an optimax and a 2001 Carb 200 with the o-ring heads. I can definitely say for 99% of the guys, it won't do much FF or EE.
    Probably better off with an EE because you won't have to pay the premium.
    But if I ever get another FF, I'll make sure to keep preaching about how great it is
  11. Likes Noah Burns, TEXAS20225 liked this post
  12. #52
    Quote Originally Posted by Radiant View Post
    Make us proud
  13. Likes TEXAS20225 liked this post
  14. #53
    Nov 2020
    New Zealand
    The FF is the one of class motors Australian F1 tunnel racing.
    All steel liners
  15. Likes joyrider liked this post
  16. #54
    Sep 2006
    Early EE's came with the 7 pedal front.
  17. #55
    Nov 2020
    New Zealand
    How early?
    I've got a 93 here.
    OD240375
    2.5 offshore carb
    Edit.
    Nup, EE is 200 small chest. (3 fingers fit in port)
    FF is big chest ( 4 fingers fit in port)
    Only 2.5 fishing motor with 7 petal other than pro max is the 1991 2.5L. (F)
    Got all these motors.
  18. Likes LakeFever liked this post
  19. #56
    Jun 2018
    Floating around
    1991 One year only iirc. 7 petal front, small chest exh same as EE
  20. #57
    Nov 2020
    New Zealand
    I'm building a f block motor currently.
    Interestingly the ff I'm working on as well only has the small exhaust plate ports
    In contrast, a 1983 2.0L 150hp motor has a promax type 2 piece plate with the large ports.
    That 2.0L motor also had a nice 9 ring crank without the oiler and big rods from memory.
    From now on I will be grabbing those 2.0L motors as they come along
  21. Likes LakeFever liked this post
  22. #58
    TX......somewhere?
    they're not talkin' bout tha exhaust exit at tha bottom of tha block.. they're referin' to tha cylinder exhaust ports.... all those things ya mentioned 'bout tha 2.0 are normal production........ 9 ring is jus pre oiler crank.....
  23. #59
    Nov 2020
    New Zealand
    Yes I realize that.
    The ff is a 4 finger width exhaust port and the EE is a 3 finger width.
    What surprises me is that even a ff with its 4 finger width cylinder port, only has a std size port in the plate and probably came off a small plate
    Then the tiny cylinder ports of the 150 2.0L feed out through large plate ports.
    Just all seems unusual to me that's all.
  24. #60
    TX......somewhere?
    tha ff plate should have about tha same size adapter plate exhaust holes as tha 2.0 motor plate.. thats something i noticed years ago.. but most early 2.0's had long skinny tuners... tha difference in tha 2.0 (large rectangular) and 2.4 small, almost square) exhaust... not much difference in tha 2.0 and tha production 2.5 exhaust plate holes..... jus merc!.. guess they had it figured out..........
    sounds like ya have a 2.4 plate if they're almost square.....
  1. Replies: 51
    Last Post: 06-18-2019, 03:25 PM
  2. Replies: 3
    Last Post: 02-11-2019, 09:52 AM
  3. Replies: 2
    Last Post: 03-11-2016, 08:07 PM
  4. Replies: 5
    Last Post: 08-10-2015, 04:25 PM
