Results 1 to 15 of 38
Thread: Offshore mid
10-21-2020, 05:32 PM #1
10-21-2020, 06:48 PM #2
I got a regular mid I want to powdercoat, couldnt it be blasted instead of sanded, why u sanding it off
10-21-2020, 07:25 PM #3
10-21-2020, 08:06 PM #4Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
If you are only running in freshwater you have plenty of options. Brackish or Salt, not so much.
10-21-2020, 09:07 PM #5The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
...looks to be first generation offshore mid. second generation ridgeback's lower mounts were simply studs...
10-22-2020, 04:47 AM #6
I prefer painting because if it gets chipped you can easily touch up.....JMPO.
You do have some guys like Bud (1Stream) on here that does a great job on PC which is very important if you decided to go that route.
He knows the environment we use/run them in, this is very important.
I also like to have them blasted and then primed well with good primer before painting. Just blast it with fine or medium grit not course. Lots of things can act up once bare aluminum surface is exposed either way.....Again JMPO
Merc 2.5 thanked for this post
10-22-2020, 06:09 AM #7
10-22-2020, 06:09 AM #8
Robert Please dont take what Im about to say wrong. But That Mid as pictured is not ready to be Powdercoated. It needs to be Blasted completely clean of all previous coating, Paint or what ever so the surface is etched. Sand Blasting is a NONO!!! Glass Beading is also a NONO!!! Sand is to course and Glass beading doesnt etch the surface and also leaves silica in the pours. That leads to out gassing and a less than desirable finish. I do marine environment Powdercoating all the time and theres more to it than simply Shooting it with Black Powdercoating. Unfortunately for Customers I end up redoing other shops Powdercoating jobs all the time. Especially on marine Environment applications. Mainly because they dont understand it. The other Extremely Important thing is Most Shops dont stock the proper Powder to coat for marine environment applications. All Powders are not the same. All the powders I use have been formulated and ASTME tested to withstand 2000 Hrs of Continuous salt spray. Another problem I see is thay dont know how to properly cure the powder for marine applications and it comes out to brittle which makes it subject to easy chipping etc. Powdercoating properly done should have some elasticity to it. Heres a Link to a thread I did some time back. https://www.screamandfly.com/showthr...Powder+Coating
10-22-2020, 06:19 AM #9
I sure do appreciate it bud. What I was doin here was just trgin get the most part done , I know i gotta take it sumwere to have it blasted to finish everything up. Ill call my buddy today and see if he can give me some info on the powder they use , also main reason I was leaning this direction , I been helping him alot with his boat and he was gonna pc. I dont know nothin bout it , but who ever does it its gotta b right.
Well crap. Gonna fill him out today and I'll get back with you on this bud. Sure do appreciate the info.
10-22-2020, 06:24 AM #10Bud Conner "Heathen" "Defending Our Constitution"
Dave Strong liked this post
10-22-2020, 07:46 AM #11The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
...everything hstream said is right on. all powdercoaters are not the same. proper knowledge of prep is a big part of pc. just the correct PSI alone for different blasting medias is critical & most don't have a clue. i've spent tens of thousands of dollars on pc, anodizing, chroming, etc... for the saltwater marine envirement & there is definately a lot to know in doing it properly. yes, the old standby of correctly prepping, epoxy priming & painting always works well. no issues at all, in fresh or salt if the painter knows what he is doing.
HStream1 thanked for this posttux974, Dave Strong liked this post
11-10-2020, 06:54 AM #12
11-10-2020, 12:17 PM #13The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
...if you have made up your mind on this, then give him a couple other parts too, like the adapter, etc...while your at it...
11-10-2020, 01:06 PM #14Bud Conner "Heathen" "Defending Our Constitution"
phillnjack thanked for this postNoah Burns, phillnjack liked this post
11-10-2020, 01:13 PM #15The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
...bingo...
running OFFSHORE and NON-OFFSHORE 300X motors
By noli in forum Technical DiscussionReplies: 2Last Post: 08-15-2015, 06:22 PM -
American Offshore 2600 NXS twin Mercury Offshore 280's
By Balaco01 in forum Hulls larger than 20'Replies: 2Last Post: 03-01-2015, 01:05 PM -
Offshore Events 3rd Annual Sunny Isle Beach Offshore Challenge
By Sharkey-Images in forum General Boating DiscussionReplies: 4Last Post: 04-30-2010, 10:35 PM
