Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
    Sep 2006
    Water pressue was 13psi, it has open carbs, cowling has venting on the side and top rear to allow air in and out but not a direct path to the carbs ,stock 2 piece adaptor plate.. I have run the same set up off and on over the years but usually in the summer when corrected air is more in the 2000+ft range(based on alky motor experiences) The air was cold and crisp and I would guess in the 800 ft range. I now see this was an incident that was probably going to happen due to my inexperiece in tuning and had been posboned by dumb luck. The motor was strong. I will replace the piston an start high with the jetting . Thx to all the replies.
  2. #17
    Mar 2004
    Brooklyn Park, MN
    It ran lean up top. With open carbs I would run 76/78 mains minimum and you would be good all year I would guess. Maybe if 30 degrees out you would want 78 or 80 and when 100 you could go to .074 in 1,3,4,6 and .076 in 2,5. Most run cylinder 2 and 5 one jet size bigger as they are the hot cylinders most agree.
    and I am by far a novice, no professional here!
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  3. #18
    Quote Originally Posted by coffeeguy View Post
    Temperature can really mess with you, fine all year then temp drops 5deg below your usual low temp and your lean.
  4. #19
    Why people take off the airbox on stockish type motors is beyond me. My pretty mellow 2.5 on the vector turns over 7500 just fine with an airbox and is pretty crucial to jetting.
  5. Likes Dave Strong, nitro_rat liked this post
  6. #20
    Mar 2004
    Brooklyn Park, MN
    For the bling! For the bling.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  7. Likes rgsauger liked this post
  8. #21
    Mar 2004
    Brooklyn Park, MN
    Don't do chit but get gas and oil all over my cowl and pan
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  9. Likes Merc 2.5, keefallan liked this post
  10. #22
    I like to take my cowl off twice a year. Once to put the motor on the boat and once to take it off the boat.
  11. Likes nitro_rat, rjdubiel liked this post
  12. #23
    Jul 2012
    Lufkin, Texas
    I've spun 2 liters to 8k with the air box on, I like to run the 2.0 type clam shell cowls so I do ditch the air box on horizontal carb motors. I hate that 2.4 200 plastic latch setup...
    Josh Peterson
  13. #24
    Did your Wiseco's have an anodized crown and underside .. ???
    If so, they don't show color or fuel wash like a bare aluminum crown does.
    Just something for the forensic pathologist's to think about ...
  14. Likes FORBESAUTO liked this post
  15. #25
    May 2001
    Hickory NC
    Jetting, ignition and wall clearance aside what I dont like is the ring on piston top thats about the size of the squish band making me think you might have had the block decked or too thin of head gasket and thus too little squish clearance.
  16. Likes FMP, Dave Strong liked this post
  1. Cold Seize
    By Fl Boy in ILL in forum Technical Discussion
    Last Post: 03-05-2010, 06:42 PM
  2. pro max cold seize ?
    By mercrazy in forum Technical Discussion
    Last Post: 07-16-2009, 09:31 PM
  3. 2.5/260 - Water Temp: How Cold Is To Cold?
    By Pachanga_rick in forum Technical Discussion
    Last Post: 07-12-2008, 06:02 PM
  4. Cold seize?
    By Stoker100 in forum Technical Discussion
    Last Post: 12-22-2003, 12:02 AM
