Results 1 to 10 of 10
Thread: Outboard Trailering Blocks
10-20-2020, 03:15 PM #1
What are you guys using to block / lock your Mercury outboards in a raised position while trailering? I have a set of aluminum tubes with plastic ends that slide down the trailering rams on my 2.5 / 200, but I'm not particularly thrilled with them. (I'm not going to mention the brand.) Any suggestions?
1992 Progression 22
Mercury Racing 250R
10-20-2020, 06:43 PM #2
2x4 works.
i used a lacrosse stick, just had the head chopped off so the lacrosse basket was now a “Y” on the shaft. Dense foam in the crotch, and that was my engine prop, went down to the trailer. Simple, cheap.1) 1995 14' Bayliner Restoration <--Click
2) Home-Made Tunnel-Boat Project <--Click
10-22-2020, 01:18 PM #3
Thanks, but I was looking for something a bit more elegant. I know there are products out there that folks are buying and using.
This is what I'm using right now: https://thmarinesupplies.com/product...ort-stick-pairLast edited by TooStroked; 10-22-2020 at 01:24 PM.
1992 Progression 22
Mercury Racing 250R
10-27-2020, 01:11 PM #4
10-27-2020, 01:49 PM #5
10-27-2020, 03:02 PM #6
It's what I used.
RockTeam Junk
10-27-2020, 06:18 PM #7
I stopped by their shop to pick up these... the cnc machines were humming, cool little shop.
they are great, soo much nicer than those crappy little plastic clips, plus the handle makes it a breeze to snap on and off.
I am not sure I like any motor toter/hydraulic stops for the engine. when I trailer the boat, the motor is vertical and jacked to max on my plate, almost impossible to drag the skeg (I guess If I broke both axles on the trailer) and even then I think the trailer would hit and not allow the motor to touch...
but if you trailer with your motor tilted, I would definitely get one to protect the hydraulic ram.
TooStroked liked this post
10-27-2020, 06:33 PM #8
10-27-2020, 08:37 PM #9
Isn't the idea of a transom saver to take the leveraged stress of a tilted engine off the transom and transfer more of the weight onto the trailer? So the style that goes from the bottom edge of the mid or the top of the lower to the rear of the trailer? Like one of these?
https://www.basspro.com/shop/en/bass...7&gclsrc=3p.ds'78 Hydrostream Viking/'98 225 ProMax
10-28-2020, 09:35 AM #10
Personally, I'm not a big fan of the "transom saver" style outboard supports. My logic is that the trailer is independent of the boat and thus moves and flexes at a different rate. Although theoretically they transfer some load to the trailer, I still don't like the possible additional movement. I'm going to try to stick with something somewhat internal to the clamp bracket and trim rams. But thank you.
1992 Progression 22
Mercury Racing 250R
New Here looking for a little help if possible with trailering a new boat
By cbellamore in forum General Boating DiscussionReplies: 11Last Post: 07-23-2009, 04:17 PM -
Trailering question
By cocacola in forum General Boating DiscussionReplies: 11Last Post: 03-24-2007, 10:32 PM -
trailering
By dlgorie@yahoo.com in forum Technical DiscussionReplies: 14Last Post: 12-06-2006, 02:02 AM -
Trailering a Hydrostream
By LSaupe in forum General Boating DiscussionReplies: 16Last Post: 07-11-2006, 07:18 PM -
Trailering Stories
By 10.5' Tunnel in forum The Scream And Fly LoungeReplies: 23Last Post: 10-29-2004, 02:37 PM
