Results 1 to 15 of 16
10-20-2020, 02:10 PM #1
10-20-2020, 05:28 PM #2Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
Yikes, good reminder. Thanks..
10-20-2020, 06:16 PM #3
Holy crap, what are they running for gas, Starbucks Dark Roast?
1992 Progression 22
Mercury Racing 250R
Capt.Insane-o liked this post
10-20-2020, 06:37 PM #45000 RPM
- Apr 2017
- Pomona ny
- 251
- 12
- 48
Was shocked how bad the air injectors actually get
10-20-2020, 08:13 PM #5Team Member
- Lake Coochiching, Ontario
- 7,755
- 272
- 485
- 1577
- 6 Post(s)
How many hours between cleaning is recommended?
LMT383 liked this post
10-20-2020, 09:01 PM #6
Looks like Mercs tar like DFI oil. Pennzoils XLF oil is what you want to use in flopti's ....and Tstat updates.
JR IN JAX liked this post
10-21-2020, 07:27 AM #7
I bought three 250's off a center C fishing boat, 460 hours $11,000
If I could get them out with out destroying them I would have loved to send them out...SALT
Ebay used ... yes I had those cleaned first...We have invented the world; WE see
10-21-2020, 09:15 AM #8
I would say it all depends. Honestly most people don't clean them until there is a big issue. The 300xs guys seem to get it, and usually have them cleaned every couple seasons or 100-200 hours I would say. Its all about what you run through them. Have bad gas, or a failed compressor and you will have something that looks like this. The air system has a major lack of filtration too so any dirt/dust/bugs in the lines get sucked right though.
EDIT: Also these motors like to run. Sitting is not doing these engines any favors.
www.InjectorService.com
Call/Text - 204-326-0390
10-21-2020, 09:20 AM #9
10-21-2020, 09:24 AM #10
10-21-2020, 09:36 AM #11
10-21-2020, 10:56 AM #12
Got them out
but it was not pretty, up north salt kills the cars
Down here boats / electronicsWe have invented the world; WE see
10-21-2020, 02:19 PM #135000 RPM
- Mar 2010
- Alberta
- 363
- 15
- 33
- 29
- 231
Ok, I've got a 2007 250 pro xs with 150 hours on it, runs fine. I had the water pump replaced and the leg resealed(by a local shop) as preventative maintenance last fall, as far as I know it needs nothing. I'm a hobby mechanic, do oil changes on the leg, winterize the motor myself each fall, One of these days I'll replace the spark plugs. I've done a lot bigger mechanical jobs on cars and equipment, but getting older and now more likely to pay people to do work for me.
If I've decided to get the air compressor system and F.I. system cleaned/checked out, what do you recommend and what services do you offer? If I bring you the motor can you look after everything and if so for approximately how much?(I'm in Alberta)
If I remove all the parts and send them to you, how much is that going to cost(approximately) and how tricky is the job, especially the putting back together part? Special tools?08 Checkmate 2100br 250xs
10-21-2020, 03:34 PM #14
Altamate - I PMed you.
10-21-2020, 03:34 PM #15Team Member
- 7,755
- 272
- 485
- 1577
- 6 Post(s)
I use the Merc race opti oil. Any good?
Optimax fuel system questions
By bullet19 in forum Technical DiscussionReplies: 0Last Post: 09-19-2016, 02:40 PM -
XS Optimax fuel system
By MERCRACING in forum Parts WantedReplies: 4Last Post: 09-16-2015, 10:52 AM -
Optimax fuel/air injector cleaning?
By jeepster21 in forum Technical DiscussionReplies: 1Last Post: 01-13-2015, 10:24 PM -
2001 optimax 200 fuel system question
By wtlee3 in forum Technical DiscussionReplies: 2Last Post: 09-27-2012, 11:34 PM -
optimax fuel system
By davemvegas in forum Technical DiscussionReplies: 0Last Post: 06-26-2012, 05:34 PM
