Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
    Nov 2020
    New Zealand
    Older thread but will add my 2 cents worth.
    For v6 motors I use some sort of internal structure to build the nose cone on.
    The equivalent in the States would be a Bob's.
    This is because it needs to stay in place in a turn if it hits something at high speed.
    For me on a race circuit this is all about safety.
    For small motors like 30hp racing which I do also, I see it as acceptable to cast polyester (reinforced bog) straight onto the gearbox.
    On these small engines I don't include a Low Water Pickup in the cone but use a transom mounted pickup feeding the pump.
    The trick is to prepare the Aluminium well.
    I use a 36 grit sanding disc to key the bullet then butter the bullet with polyester bog.
    Then a pre prepared cardboard or plastic witches hat shaped mold is filled with bog and held in place until set.
    This is not an easy task.
    The bog needs to be packed into the mold so that there are no air cavities.
    Much easier said than done.
    Once done, this forms the main shape of the cone that is then added to and finish shaped.
    Done well, they dontClick image for larger version.
ID:	514824 come off.
    My experience has been that polyester adheres to aluminium much better than epoxy does so if a cone is to be made from epoxy then a butter layer of polyester is used on the Aluminium.
  2. Thanks LakeFever thanked for this post
    Likes LakeFever, rgsauger liked this post
  3. #17
    Sep 2021
    New Richmond, Ohio
    try ron hill he makes some noise cones for small engines i think its hill manine 0n the west coast
  4. #18
    Nov 2020
    New Zealand
    Ron Hill is 15,000 miles from my place.
    If I was going to make one with a integral LWP it would be of the Terminator type.Click image for larger version.
Name:	cone work 1.jpg
  5. Likes LakeFever, David - WI liked this post
  6. #19
    Oct 2018
    Tennessee
    (Rip. Whiteally02) -dad
  7. Likes LakeFever liked this post
  8. #20
    Oct 2018
    Tennessee
    I hit a submarine log and ask if anyone has swept asporty, I'm not completely done but I have been working on it, boat is over a100, Noone responded as I ask if anyone had done it before
  9. #21
    Nov 2020
    New Zealand
    A Racing friend of mine is planning needle point cone on a small vee bottom race boat (30)hp.
    We both also run V6 circuit boats.
    I don't use needle points as I believe that they don't behave well in turns.
    He is an ex FI tunnel driver and reckons that needle point is ok on a fast vee bottom boat?
  10. #22
    Feb 2005
    seattle
    if your max speed is not near or over its a waste of time.
  11. #23
    Jan 2003
    aalsmeer
    Ever thought about 3D aluminium printing!
    I have no idea about the cost or if it would be possible to start printing on a gearcase or seperate cone to be glued on
    That is also something i would like to try but getting the right compagny would be a search
  1. Nose Cone help
    By speediracer4 in forum Technical Discussion
    Last Post: 04-13-2011, 11:19 PM
  2. Nose cone
    By rdkvector in forum Props, Setup, and Rigging
    Last Post: 12-15-2010, 09:03 AM
