Results 1 to 2 of 2
    Dec 2017
    Edenton nc
    2007 Optimax 250 rigging ?
    I'm new to the outboard world
    I'm looking at a 2007 250 Merc opti xs
    No prop or rigging
    Does this engine use fly by wire or cables and what all do I need to make it 100 percent?
    Also can I see instruments on my simrad GO9
    I know its alot but I can't find these answers with any accuracy
    Figure the pros here know
    Tia
    Sep 2012
    [QUOTE=Edenton;3239296]I'm new to the outboard world
    No prop or rigging
    No Fly by wire. You will need either the 8 prong old style harness with an adapter or the newer 14 pin harness. You will need battery cable, throttle cable, shift cable, Oil bottle, 2 oil lines, fuel line, Blue line from engine with resistor for smartcraft signal.
    I am just about sure that it is compatable, I think you will need a vessel view link to work with the go9.
  1. Rigging tube replacement help 2007 300XS
    By 288sunny in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 11-05-2018, 03:07 PM
  2. 2007 SeaBoss with 115 Optimax
    By Modus in forum Hulls up to 20'
    Last Post: 07-02-2018, 08:33 PM
  3. 200 Optimax ECU (2007 vs 2011)
    By kostas74 in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 02-10-2012, 05:29 PM
