Results 1 to 9 of 9
Thread: merc xr6 ignition
10-16-2020, 12:35 PM #1New Member
- Oct 2020
- hacksneck,va
merc xr6 ignition
Sorry guys I know this an old subject. I have a 93 Merc XR6 with 40 amp ignition can I change this to a 16 amp system. Do i have to swap flywheel, stator and trigger? Or use my old trigger? I have a 87 16 amp set up i can use with my regulator and switch boxes. Any advice would be great.
10-16-2020, 02:19 PM #2
If your using electronics , spinning it under 7k then keep the 40 , if turning it high and not hardly any electrics it b fine
10-16-2020, 09:44 PM #35000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
Trigger part numbers look the same to me unless its a later model XR6.
10-17-2020, 06:53 AM #4
stator, flywheel.. if you use ONE of your 40 rec/regs ok... if you use tha reg. from tha '87 you will need ta add a rectifier.....
Merc 2.5 liked this post
10-17-2020, 05:00 PM #5
We actually just did this to a buddys rig ,and today was 1st real test ,he got another 5mph with 2 people loaded to the gills. Yet to test with 1 person , it definitely helped, hole shot was better to
Seems like alot but those #s are from GPS running consistently
10-17-2020, 06:41 PM #6Team Member
- Lake Coochiching, Ontario
- 7,766
- 276
- 487
- 1590
- 6 Post(s)
Would an XR6 make power at 7000 rpm?
10-17-2020, 11:49 PM #7
No.
10-18-2020, 12:16 AM #8
10-18-2020, 05:47 AM #9
99 triton 18.5ft with stock 2.5 200
merc xr6 ignition
By babydumpling in forum Parts WantedReplies: 1Last Post: 10-16-2020, 01:50 PM -
Merc 3.0 ignition
By lodin61 in forum Technical DiscussionReplies: 3Last Post: 06-10-2008, 02:38 PM -
More Merc Ignition ?'s
By CompKing in forum Technical DiscussionReplies: 3Last Post: 12-19-2002, 07:18 PM
