Results 1 to 6 of 6
Thread: 1987 mercury 60 hp piston damage
10-12-2020, 09:08 PM #1Junior Member
- Sep 2020
- Ottawa canada
Hello, I had a piston failure in my number 1 cylinder and I was wondering if anyone might be able to identify the root cause from seeing the piston. The engine did not seize but the metal pushed onto the plug shorted the spark killing the one cylinder. I recently had to replace the stator and timing trigger but the motor ran fine for a month before this occurred. From the picture can one tell if this was a progressive failure or does this type of failure happen quickly.
thanks for any help.
jumbo 3905
10-12-2020, 11:53 PM #2Screaming And Flying!
- Dec 2001
- 9,503
- 271
- 191
- 1976
The old...... Mercs do that ,The piston has that high Dome that keeps the exhaust and intake seperated..It runs hot and acts like a heat sink. Low octain gas or lugging the motor will put the motor at risk. Merc cut the dones a 1/16 of an inch to help the problem and lower the timing advance. Your timing might be a bit advanced where you replaced parts. Pop a nudda piston in and sail on.Check/ retard the timing and don't lug the rpms.
Merc 2.5 liked this post
10-13-2020, 06:43 AM #3Junior Member
- Sep 2020
- Ottawa canada
10-13-2020, 08:27 AM #4Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Use Shell 91 Vpower. Check all is correct with the timing and the carb.
10-13-2020, 10:52 AM #5
Did you do a full link and sync after installing the new parts?
10-13-2020, 04:20 PM #6Junior Member
- Sep 2020
- Ottawa canada
Mercury 2.5l retarded timing cause engine damage?
By Rider_560 in forum Technical DiscussionReplies: 3Last Post: 09-10-2018, 09:49 AM -
1992 XRI piston damage
By wakepics in forum Technical DiscussionReplies: 6Last Post: 07-30-2018, 06:59 AM -
Mercury Tech: Cylider damage, Mercury V6
By Droll in forum Technical DiscussionReplies: 2Last Post: 07-16-2010, 09:55 PM -
86' 175hp merc piston damage
By luckybuff in forum Technical DiscussionReplies: 2Last Post: 05-07-2010, 10:22 PM -
What caused this BP piston damage?
By Alan Power in forum Technical DiscussionReplies: 22Last Post: 09-19-2006, 08:37 PM
