Results 1 to 2 of 2
    Oct 2017
    Jackson Ga
    Blow out ring question!!
    I’m currently testing out props trying to find the right one.. I ran A 26 pitch trophy plus prop today and was running 6100-6200 rpm. My question is... will putting the exhaust ring on the prop lower my top end rpm? I know Without it.. it helps slip for a hole shot but if I use the ring will it lower my RPM on the top?
    Jan 2015
    No, it will not effect how the prop runs once the boat is on plane. Only affects hole shot and at how low of a speed boat will fall off plane.
  1. Do I need q blow out ring?
    By Cervelo777 in forum Props, Setup, and Rigging
    Last Post: 11-10-2018, 01:16 PM
  2. Blow out ring
    By racer in forum Misc. Parts and Accessories
    Last Post: 04-03-2014, 11:56 AM
  3. Blow Out Ring Question
    By RLC PE in forum Technical Discussion
    Last Post: 11-26-2007, 01:28 PM
  4. Blow out ring
    By reddog1319 in forum Technical Discussion
    Last Post: 04-09-2006, 10:44 AM
