Results 1 to 13 of 13
Thread: prop repair
    Aug 2009
    mpls,mn
    prop repair
    Wheres a good place to get a lighting et 28 p repaired has a 1 inch crack on one blade upper top.
    Pekin, IL
    I know those suckers are expensive and ya don't need it as a paper weight but I had one fixed twice then sold it to a guy that also had it fixed twice. After it resurfaced (same spot) I gave him his money back. Loved my ET but had more money in repairs then buying a new one would cost. Might be just my experience and not the norm. DAH did the repair.
    Rock
    Team Junk
  3. Likes Euroski, David - WI liked this post
    Aug 2009
    mpls,mn
    Quote Originally Posted by rock View Post
    Rock
    Yeah I know it sucks even repaired I would not trust it at speed,was going to send to dah but there done with. The cut heads went from 120psi to 130psi ran better though.I just got a mod 280 and the Bridgeport is now going on garys boat so may try those heads on the b/p as it is a stock powerhead.
    Pekin, IL
    If you want to send those heads back I will cut them again at no charge. Hard to believe a cut to 32 cc (maybe a little less ) only netted 10 lbs.
    Rock
    Team Junk
    Aug 2009
    mpls,mn
    Rock
    I know the stock 200 all chrome never blown I said to gary needs a rering they must be worn out but you would'nt think at 120 on all 6? would be that worn.
    Sep 2017
    Ashland city tn
    hey rock. Can u cut oring heads to make em run with gaskets?
    Aug 2006
    Cincinnati, Oh
    Quote Originally Posted by racervboat View Post
    ...was going to send to dah but there done with...
    No they're not done... Dan
    https://www.screamandfly.com/showthr...s-isn%92t-gone!
  9. Thanks DAHpropellers, phillnjack thanked for this post
    Likes DAHpropellers, phillnjack liked this post
    Pekin, IL
    Quote Originally Posted by Merc 2.5 View Post
    Never done it but if it requires no more than removing the groove I don't see why not.
    Rock
    Team Junk
    Oct 2020
    Antioch IL
    We are still here, but we are under new management and are relocating the shop to Antioch IL. We are planning to open to the public by early - mid summer 2021. As for repairing a 1" crack on a blade, that wouldn't be a problem at all. We are currently training with John Janaky and we fixed a prop that had a 1 1/2" - 2" chunk ripped out of it and it looked like brand new when we were finished. Our welder is very experienced and skilled at welding thin gauge material. If you have any other questions or concerns, go to www.dahpropellers.com and give us a call or shoot us an email. We would be happy to talk with you.
  12. Thanks phillnjack thanked for this post
    Likes phillnjack liked this post
    Aug 2009
    mpls,mn
    Rock
    Don't know about that but I got gasket heads on my 280.
  14. #11
    Sep 2017
    Ashland city tn
    Rock
    the oring groove seems pretty deep , womdering what compression would b afterwards
    Pekin, IL
    Seems I remember removing .010 equals .7cc. Do the math.
    Rock
    Team Junk
  16. #13
    Sep 2017
    Ashland city tn
    So I talked to perry and he said it take bout .180 to get rid o ring groove and compression will b at 180ish, 26cc I thought it looked like alot.
  1. prop repair
    By javelin225 in forum Props, Setup, and Rigging
    Last Post: 02-09-2013, 01:04 PM
  2. Prop repair ?
    By catmanzr in forum Props, Setup, and Rigging
    Last Post: 07-14-2012, 06:00 AM
  3. The prop no one can repair....
    By MERC1000 in forum Props, Setup, and Rigging
    Last Post: 11-17-2009, 10:16 PM
  4. Prop repair?
    By Impulsive in forum Technical Discussion
    Last Post: 07-03-2008, 03:41 PM
  5. Prop repair..if yes...where?
    By DaveR in forum Technical Discussion
    Last Post: 06-04-2001, 10:35 AM
