Results 1 to 7 of 7
10-05-2020, 06:21 PM #1Junior Member
- Oct 2015
- tortola
- 15
Help with picking right Gears ratio For Mercury Lowerunit
Good day, I need some help in deciding which gears to get for my Sportmaster LowerUnit. I’m stuck between the 1.62, and the 1.75. I would like someone to explain what performance each gear would give. I have a 21 ft shadow with a 300xs. I would like some help in helping me pick the right gear set for my boat.
Help me understand different gears
10-05-2020, 06:44 PM #2
I love the 1.62 on mine.
"Confidence" is that wonderful feeling you had right before you fully understood your true situation.- Unknown
I don’t know what effect these men will have upon the enemy, but, by God, they terrify me.- Duke of Wellington“I am not afraid of an Army of lions lead by a sheep; I am afraid of sheep lead by a lion.” – Alexander the Great
Whoever said the pen is mightier than the sword obviously never encountered automatic weapons.-Douglas MacArthur
Allison GSE 300XS
10-07-2020, 11:02 PM #3
Gearing relates to both redline rpms and prop. I don't know the Shadow too well, but for many light, fast boats the props available for the 300XS would cause the engine to hit redline because of the ratio with a 1.75. 1.62 leaves you more freedom. I do know that when I reower with eithe a 300XS or a 300r on my 21' Eliminator, I want 1.62.
I don't know if the shaft size is the same for the 300r, but its existence has resulted in some higher pitched (and higher priced) props coming on the market.
Someone on here probably owns a Shadow with a 300XS and that will be your best answer.
Oh, and I bet the resale market for a motor with a 1.62 is better than a 1.75.Per Rock:
"Once I bought my first Hydrostream boating changed forever for me."
Per my hero Instigator:
"I try not to let common sense interfere w/my boat buying decisions."
Pat Gent
cell 954-249-3246
'78 Hydrostream Vandal (being rebuilt)
'86 21' Eliminator Daytona, 300 OMC V-8 (Li'l Toy III)
10-09-2020, 08:27 PM #4
1.62
10-09-2020, 10:52 PM #5Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,641
- 606
- 920
- 1698
- 7138
- 3 Post(s)
That hull won't utilize the 1.62 to where its worth giving up the acceleration of a 1.75. If you were running a lightweight boat or tunnel then I would go with a 62. The difference is a lot more then I would have thought until I rode in the same boat and we swapped them back and forth on a 20' LCB. Run a two pitch steeper propeller and you will net the same top end but still have better acceleration and planing capability.
A 1.75 with a 28 should put you in the mid 80s and good load carrying capabilities based on what we have seen with Randy's checkmates.
tunnelfun liked this post
10-09-2020, 10:56 PM #65000 RPM
- Apr 2017
- Pomona ny
- 251
- 12
- 48
10-10-2020, 10:31 AM #75000 RPM
- Apr 2011
- Western NC
- 113
Mercury 20" racing CLE 2 to 1 ratio gears
By The War Canoe in forum Lower UnitsReplies: 1Last Post: 08-18-2014, 10:59 AM -
Getting lowerunit gears kryoed
By Avance 33 in forum Technical DiscussionReplies: 6Last Post: 12-28-2005, 07:20 PM
