Results 1 to 5 of 5
Thread: 300 promax ecu casing
10-01-2020, 08:59 AM #15000 RPM
- Feb 2019
- Plainview, NY
- 142
- 66
- 11
is there anyone out there that fixes the plug parts of the ecu?
10-01-2020, 09:38 AM #2
I would think Simon or Brucato would be able to do that... otherwise CDI Electronics has a repair service.
Brand New ECM & EFI Systems tend to be costly. With PREMIER REPAIR SERVICES, you can send your current ECM or EFI into CDI Electronics and let the professionals rebuild or reprogram your system for a fraction of the cost.
10-01-2020, 11:21 AM #3
10-01-2020, 11:28 AM #45000 RPM
- Feb 2019
- Plainview, NY
- 142
- 66
- 11
its a 99 or a 98 promax i with the 2 ecu boxes the bottom box fuel, has a cracked plug adapter
10-01-2020, 10:12 PM #5
The good thing is that it's not the Ignition box.
The fuel box .... a lot of guy ran / run the 250XB as first choice and then a 250EFI as a second choice. Usually find them pretty inexpensive in "misc parts" in the want add's .
Or take your chances on E-bay .. maybe a local marina. Food for thought .
Those boxes are poured closed (full) with a silicon like glue. I don't know of anybody that's tried to get the turtle out of the shell , other than to see what's inside.
If it's cracked , not knowing how bad , to inside the box , the clip the holds the harness etc. I would rough it up with 220 sand paper , and use an epoxy like JB Weld to fix the part. Then when you put it back together , use some black silicon on the rubber boot to hold the harness clipped in place ... Let us know , or take some pictures ..
gear casing
By screwball in forum Technical DiscussionReplies: 2Last Post: 11-12-2011, 01:38 PM
