Results 1 to 9 of 9
    Dec 2017
    Lake Ashby, New Smyrna Beach FL
    Verado L/U question
    Does a 2011 Verado 300 Pro use the same lower unit as a 2007+ 3.0 or 3.2L motor?
    Feb 2006
    Formerly Central WI/LOTO Currently PHX AZ
    Quote Originally Posted by TraceF3 View Post
    No. External diameter is the same, and that’s about where the similarities stop.
    The Verado case has preloaded bearings and the shafts and shift forks are different, I believe.
    A problem is only a problem when viewed as a problem...
    Quote Originally Posted by HydroSkreamin View Post
    Correct..and they suffer the same water intrusion issues as the 2 stroke cases, and after as much you just throw them on the shiz heap and get a new one out of the box.
  4. Likes TEXAS20225 liked this post
    Dayum Capt. Double shot Thursday ... put the Verado case in the same class as the 3.0 / 3.2 case .... and then throwd em both in the .44c a pound pile ...
    You do bring all your scrap aluminum to .... #1 clean condition before ya turn it in
    Don't Cha .... ???
  6. Likes TEXAS20225 liked this post
    ...wonder how sei is going to fix all that?...
  8. Likes HydroSkreamin liked this post
    Feb 2006
    SEI= Same Engineering Issues
  10. Likes TEXAS20225 liked this post
  11. #7
    Don't Cha .... ???
    I do have to do something about that soon. There is damn near a full pick up box full of rusty shafts gears and bearings and housings where the pinion gear came out the side
  12. Likes TEXAS20225 liked this post
  13. #8
    Jul 2002
    FT WORTH, TEXAS
    i have a whole set of guts out of a case that was on a 2008 200 xs everything different then a regular 3.0 case if any one needs um
  14. #9
    Pm Tex
  1. 350-400 hp.Verado front tie bar arm stregnth and tie bar question.
    By Mini Max in forum Technical Discussion
    Last Post: 05-19-2018, 10:43 AM
  2. Mercury Tech: verado question trim issue
    By R.grover in forum Technical Discussion
    Last Post: 04-01-2016, 05:41 PM
  3. 2006 275 Verado Question
    By Patrick85ed in forum Technical Discussion
    Last Post: 02-27-2013, 04:55 PM
  4. Mercury Verado 275 HP Riggin Question
    By Table Top in forum Technical Discussion
    Last Post: 11-07-2011, 10:33 PM
  5. verado question
    By mrcrsr in forum Technical Discussion
    Last Post: 06-15-2009, 06:26 AM
