Results 91 to 97 of 97
Thread: No more ecu remapping ??
05-18-2022, 03:05 AM #91
by the way why do you guys always seem to have these nice calm waters, i always end up in the rough stuff
even my gopro lifts it,s eye skywards
Chaz my friend when do we get to see your gopro footage!!! ?
05-18-2022, 11:57 AM #92
Broken English is 100x better than no English. For those of us that are half blind and not familiar with tuner studio ... it's hard to follow. Closed caption would be a great second choice. And yes brother, I have still watched every video you have made .... MANY TIMES with glasses and a magnifying glass ...
First fire up, ready to go to the ramp with test wheel ... tuning is restricted to :
Inlet temp rheostat (good for aprox 10% one direction or the other) slotted crank trigger eye (both ways) Global fuel pressure adjustment (Aeromotive) Taking an extra handful of jets .. err ... injectors of known value , 40-50 sparkplugs + MOROSO light.
While it lacks individual cylinder tuning , it's the best I have for now.
Shift interrupt .. drunken wobblers @ our sandbar with the current ripping and parking at crowded waterway restaurants don't always give you time to slip it in neutral , turn the key off, plop it in gear .. start the motor .. slip the other one in neutral ... etc, etc, before running someone over or crashing into the dock in front of 100 people ..
Flywheel : ring can be changed .. would be nice to use the ONE IT CAME WITH
Electric Oil pump : Idles @ 100:1 goes to 40:1 @ WFO The 300x program allows for a factory .030 (sorry .75 mm) factory return. I made a fixture to change jets (stainless NOS) and have tried .022 to .040 returns. No power there, however, I can make it smoke a little less after break-in.
I'd like to add A/C to my wish list ..
I had to throttle with one hand, steer with my knee, and film with the other hand. I had to pull ahead and out of the channel to see who won at the marker .. so my filming ... sukked
I promise to do better next time ...
Electric boat motors .... Ppppfffttttttttttt Here's one that has enough battery to last the full day ...
powerabout liked this post
05-18-2022, 12:17 PM #93
Since you asked so nicely i will do a proper voice over video the end of the year
I want to get some full throttle numbers this summer
I can hook up the ultimate remotely to the injectors and atleast run them in the test tank
Good news is a 60-2 wheel is also no problem when you get loose from the waves
Then Hopefully next year run autotune on the water
I will need somebody to video that as i have my hands full with the hynautic steering
So what are your thoughts on visiting europe?
05-18-2022, 08:21 PM #94
But, but, but .. my junk is in Floor-ee-da ..
Wait, how far are you from Amsterdam ..
Ik heb je meer dan eens aangeboden om hier in het paradijs te blijven.Ik zou graag Europa zien, maar je zou me waarschijnlijk huizen laten schilderen in plaats van me mee te nemen naar de Nederlandse Gran Prix.
05-19-2022, 07:35 AM #95
No need to bring your junk!
My junk is more than enough for both of us
Amsterdam better stay away, only tree huggers there who close down modern coal plants and replace them with tree burning installations because somebody in Brussel thinks that is environmently friendly
If you want to see a real race we should go to the DTM real cars not those overpaid dyson machines
No wurries about painting i will have couple of 150 fourstroke heads ready for you to weld up, build some compression
05-19-2022, 10:04 PM #96Member
- Jun 2014
- walking on the sun
- 45
- 40
- 13
The fueltech is great, for some reason i was thinking the FT600 was the only ECU that was waterproof but no the FT450 and FT550 are waterproof aswell. The issue with the megasquirt stuff is their software end is very lacking, and the ECU's aren't waterproof, plus you spend $1000 on their goldbox with harness and then you gotta spend another $900 for a racepack to get data in real time. Where as the FT550 is waterproof and around $1800 with a way better software system and touchscreen dash where you can alter things on the fly. Haltech is great as well only down side is their ECU's dont do well with marine applications atleast the ones ive seen are very finnicky with humidity and water seen a ton of their elite 1500s break in jetski stuff and pretty lacking in terms of bang for buck power from an I/O stand point.
The fueltech has an insanely fast fuel correction closed loop system. Just target an AFR and it'll autocorrect for you in real time as your making a pass lol. Holley and fueltech are the best for that.
Im also subbed to joe simpson he's a great guy and no B.S. Look up "Devin vanderhoof" on youtube he's one of the top Holley ECU wiring gurus in the industry.
I think an aftermarket ECU that is Plug and play with the new 4 stroke stuff would be a big game changer and be a legit work around with the EPA and mercury lawsuit stuff for reflashing ECU's.Last edited by d00m; 05-19-2022 at 10:11 PM.
05-20-2022, 04:52 AM #97
Megasquirt software lacking!, can,t argue with you there
put togehter the mercury 60-6 code in september 2010 and it,s still not part of the stock code
i can,t seem to get these guys to do something
they even fffup the stock code for the ultimate , you can,t run basic trigger on more than 8 cylinders
it is no problem for the DIY MS3 but because the AMP-EFI products are a bit different they make a special version of the code for them
the Ultimate is IP65 so unless your boat is sinking , don,t think that is the major issue
like i mentioned before a Missing Tooth wheel configuration can be run by anything especially if in fuel only ( hybrid form)
so FuelTech, Holly , Motec , EFI technologie , etc go ahead
but lets just stop talking about them and installing them and let everybody know what you like and did not like about them
i do, unfortunatly i had i dislocated shoulder last monday so it,s gonna be a couple of weeks i hope to get back to the water
d00m liked this post
Verado PCM reflashing/remapping
By btsmbass in forum Technical DiscussionReplies: 2Last Post: 03-13-2014, 07:14 AM -
Remapping a 2003 200 hp ficht
By hydraboy in forum Technical DiscussionReplies: 1Last Post: 09-12-2013, 09:19 PM -
Verado 250 remapping
By Vasanna in forum Technical DiscussionReplies: 8Last Post: 12-25-2009, 12:33 PM -
Mercury Tech: Remapping cost
By ctered in forum Technical DiscussionReplies: 0Last Post: 05-24-2009, 10:14 PM -
225 EFI ECU Remapping
By bep078 in forum Technical DiscussionReplies: 9Last Post: 11-11-2007, 03:13 PM
