Results 1 to 13 of 13
    Jul 2020
    Ft Pierce, FL
    Help reading plugs
    Ok y'all. I finished the install of C70TLRZ carbs on my 2009 50TLR. I made some runs at WOT. How do these plugs look?
ID:	473901 Click image for larger version.
ID:	473902 plugs 1 and 2.
    Jul 2020
    Ft Pierce, FL
ID:	473903 and plug 3.
    Rusty
  4. Likes pkstv liked this post
    Jun 2012
    Canada
    http://www.nightrider.com/biketech/readplugs.htm
    Teach a man to fish?
    Reality: I'm no expert, so my comments aren't worth much.
  6. Likes keefallan liked this post
    Sep 2017
    Ashland city tn
    u have to look at the ring at very very bottom of porcelain. Easiest is to cut the plug open and look. Thats where it matters tho and its kinda hard to see , if that's to much work read pistons. Get new set plugs need be lookin at burn on strap also but it n rough shape
Name:	Screenshot_20200924-055550_Samsung Internet.jpg
    Stole this pic from chaz
  8. Thanks Capt Fin thanked for this post
    Jul 2020
    Ft Pierce, FL
    Quote Originally Posted by Merc 2.5 View Post
    Thanks for the direction. I'm headed out today to pick up a set of plugs for a few WOT runs and to cut open.
    If you want an accurate representation of whats going on inside . It's best to warm the motor up on old plugs . Put the new ones in , run the motor up to wide open with the boat tied to the trailer and a test wheel on the motor . Let it run 10 seconds wide open and turn the key off .. pull the plugs and put them in a piece of cardboard (in order)
    If you have a lighted magnifying lens .. as 2.5 sez .. the ring at the bottom is fuel load, the center electrode and the strap will show the plugs heat and OAL temp . Timing will effect how much heat gets into the strap. Don't let the mark make its way around the bend .. flirtin with disaster ..
    Jul 2020
    Ft Pierce, FL
    I was going to bring the new set of plugs with me out on the water, warm the motor up, install new plugs, do some WOT runs and kill the motor. Then I was going to bring the boat back in on the old plugs. I've done some reading since our last posts and your info seems spot on. I really appreciate it.
    Jul 2020
    Ft Pierce, FL
    Ok, update. Warmed the motor up on old plugs and installed new plugs. Ran the boat at WOT for about 4-5 minutes up the channel and cut the motor. Powered in on old plugs. Here's what the new plugs look like from top to bottom 1, 2, and 3.
    Jul 2020
    Ft Pierce, FL
  14. #11
    Aug 2017
    Grand Cayman
    Here’s a screenshot of a graphic plug reading chart I saved a while back from the Yellowbullet forums:
    Bear in mind this is for a four-stroke, but I think the same principles apply as to heat range and jetting. A rich 2-stroke plug may be wet with oil as well, since unlike a 4-stroke the oil is in the fuel.
    BTW: You need to be using a magnifying glass with good light to properly read plugs and it’s hard and sometimes misleading to read plugs from a photo someone takes, unless it’s magnified and has really good definition.
    Jul 2020
    Ft Pierce, FL
    I just cut more threads back from the first two plugs and revealed the true carbon ring. All three look like this...
    With my 14p prop it falls on its face at 3800 rpm and I have to back it way off till it clears out then I can slowly run it up to rpm. With a 10p prop it doesn't fall on its face until WOT. Any ideas? Can I go one main jet size smaller from a 145 to a 140?
  16. #13
    When you cut the plugs on the thread side , you run the risk of wiping the ring off.
    You can cut them from the top side and slide the porcelain out of the body.
    The three plugs you had in your hand show a grey ring at the base. Once cut , not so much.
    The discoloration of the ground strap looks to be just before the bend on the first two starting to go around the bend on the one to the right.
    save the body too , look at it from the side , you can see how far the heat traveled.
    An oldie .. but goodie ...
    https://www.strappe.com/plugs.html
    How to cut plugs ...
  17. Thanks Capt Fin, InjectorService thanked for this post
    Likes Capt Fin, Glasstream15 liked this post
  1. reading plugs
    By texasvector in forum Technical Discussion
    Last Post: 12-13-2013, 09:49 AM
  2. Reading your plugs!?
    By MidnightCarving in forum Technical Discussion
    Last Post: 04-30-2011, 08:31 PM
  3. Reading plugs
    By supergenius74 in forum Technical Discussion
    Last Post: 05-31-2004, 07:21 PM
  4. need help reading plugs
    By Tom in forum Technical Discussion
    Last Post: 04-06-2002, 08:24 AM
  5. Reading Plugs and Pistons
    By Craig Knight in forum Technical Discussion
    Last Post: 09-04-2001, 11:56 AM
