Results 1 to 15 of 28
    Oct 2007
    georgia
    Xr6 cones with sport master internals
    Xr6 housing with j.c.'s nosecone 2.1 gearatio. 15 inch shaft and billet carrier. Does have reverse. 3850.00 text or call Kelly for pics.678-313-8801
    Oct 2007
    georgia
    Sold
    Apr 2008
    georgia
    Quote Originally Posted by ckp73 View Post
    Sold
    Do you have another one or know where to get one?
    please advise
    thanks Greg scott
    Oct 2007
    georgia
    Quote Originally Posted by greg scott View Post
    please advise
    thanks Greg scott
    Sure I have a couple morecall me inmy shop phone monday. 7068644976
    Oct 2021
    Orlando, FL
    I need a 3.0x lower sportmaster 1.62. Have any?
    Southeast Texas
    Are these XR6 lowers with cones(who's cone) with SM internals. If so, how much and any pics?.. thank you
    RIP Todd Carter, Ronnie, Galen...
    You'll never be forgotten
    Aug 2017
    Grand Cayman
    The one advertised above, which I bought, is an XR6 case with a Bob’s Bigfoot nose cone and (reportedly) cutdown SM 2:1 gears. It has a used billet carrier installed.
    It also had a slow leak on the side that was seeping oil from under the epoxy, which I discovered - luckily before I installed it on my boat - was due to cracked welding on the side. In short, the case was junk, unless someone can pull it apart and weld it up properly. I have an agreement with the vendor that he would replace the case, which he kept putting off due to him being too busy servicing other customers, and now he won’t respond to emails.
    So, good luck to you if you decide to purchase from this vendor.
    Here’s some pics of what it looked like after I pulled the epoxy bubble off the side of it:
    Attached Thumbnails Attached Thumbnails C23E6DAD-C821-43FF-BCF5-4489981033A0.jpg   30ED6635-D824-455F-895F-F7914BDBE016.jpg   2B8ED656-D851-4350-BE3A-B104E53B0C73.jpg
  8. Thanks David - WI thanked for this post
  9. #8
    Mar 2002
    Rockford, MI
    That sucks. Hope you get this resolved.
    "The Flying Clamato"
    ...This ain't no Party, This ain't no Disco, this ain't no foolin around..."Talking Heads - Life During Wartime"
    The G-Train has left the station.
  10. #9
    Aug 2017
    Grand Cayman
    Quote Originally Posted by G-Train View Post
    Yep, that makes two of us. I thought I had an agreement to settle this matter but the man has gone incommunicado on me. Between overseas UPS shipping ($760) and then 27% import tax on the unit, I have ~$5,000 invested in something that I can’t use except for spare parts.
  11. #10
    PARADISE /Naples
    Ouch!
  12. #11
    Aug 2009
    mpls,mn
    Quote Originally Posted by CI STV View Post
    Thats not an xr6 case it's a 2 liter xr2 case small bullet. When there busted or cracked and welded on the side like that they always re crack just to thin on the sides.
  13. Thanks CI STV thanked for this post
  14. #12
    Aug 2017
    Grand Cayman
    Then it’s even worse than I thought. Isn’t the XR6 also a small (4.25”) dia. Case?
  15. #13
    Aug 2009
    mpls,mn
    Then it’s even worse than I thought. Isn’t the XR6 also a small (4.75”) dia. Case?
    Yes it is xr6 is small case and so is xr2 late 80's case.You can tell from the rear slots above the cav plate xr6 would have anodes on the side. 4 3/4 large case, small 4 1/4 case.
  16. Likes MrG liked this post
  17. #14
    Aug 2017
    Grand Cayman
    Quote Originally Posted by racervboat View Post
    Thanks for pointing that out. I did not know that. I take it that the XR2s are weaker than the XR6s then?
    Seems like I really got ripped. The oil was also full of (non-magnetic) gunk, but he claimed that was a moly additive that he used. I’m really starting to get p!ssed with this guy now. He recently responded to my emails after several weeks and said that he’s still trying to find me another case that’s not cracked, because the last three that he located were cracked. I’m starting to wonder if it’s him or me that’s cracked. At some point I’m just going to sue him.
  18. #15
    Aug 2009
    mpls,mn
    Although they did make a 4 3/4 dia xr6 i assume you thought you were buying the small case lower with sporty internals as a high performance gearcase.
