Results 1 to 4 of 4
    May 2001
    Maine
    Mercury Outboard Grease Fittings
    Hate to ask such a numb question but can you grease Mercury grease fittings with a normal pump grease gun? Just doing a 100 hour grease job and the head wont stay on the fitting and when I adjust the threads on the gun fitting lose enough to go over the fitting it leaks when I pump it. Same issue on all motor fittings, tilt pin, swivel and pully. I use the same grease gun om my John Deere tractor and it works fine.
    Houston, TX
    That's weird. My old merc greases the same as my truck. Not sure on new stuff
    May 2001
    Maine
    Just ordered a LockNLube head for the grease gun to see if that will help. Another interesting observation is several of the fittings are a press fit and some are screw in...
    May 2001
    Maine
    The LockNLube head solved the problem... awesome tool & should have pruchased one years ago
  5. Likes InjectorService liked this post
  1. Mercury outboard grease points..........
    By Mtb3364 in forum Technical Discussion
    Last Post: 07-26-2016, 09:28 PM
  2. Manual jackplate. Grease or no grease?
    By Mr. Demeanor in forum Technical Discussion
    Last Post: 05-11-2011, 01:12 PM
  3. where to get ss thru-hull fittings for mercury outboard trim lines?
    By syclone01 in forum General Boating Discussion
    Last Post: 02-18-2010, 03:15 PM
