Results 1 to 4 of 4
Thread: Mercury Outboard Grease Fittings
09-23-2020, 02:16 PM #15000 RPM
- May 2001
- Maine
- 983
- 35
- 43
- 171
Hate to ask such a numb question but can you grease Mercury grease fittings with a normal pump grease gun? Just doing a 100 hour grease job and the head wont stay on the fitting and when I adjust the threads on the gun fitting lose enough to go over the fitting it leaks when I pump it. Same issue on all motor fittings, tilt pin, swivel and pully. I use the same grease gun om my John Deere tractor and it works fine.
09-23-2020, 10:13 PM #2
That's weird. My old merc greases the same as my truck. Not sure on new stuff
09-24-2020, 01:40 PM #35000 RPM
- May 2001
- Maine
- 983
- 35
- 43
- 171
Just ordered a LockNLube head for the grease gun to see if that will help. Another interesting observation is several of the fittings are a press fit and some are screw in...
09-27-2020, 02:40 PM #45000 RPM
- May 2001
- Maine
- 983
- 35
- 43
- 171
The LockNLube head solved the problem... awesome tool & should have pruchased one years ago
InjectorService liked this post
Mercury outboard grease points..........
By Mtb3364 in forum Technical DiscussionReplies: 0Last Post: 07-26-2016, 09:28 PM -
Manual jackplate. Grease or no grease?
By Mr. Demeanor in forum Technical DiscussionReplies: 9Last Post: 05-11-2011, 01:12 PM -
where to get ss thru-hull fittings for mercury outboard trim lines?
By syclone01 in forum General Boating DiscussionReplies: 5Last Post: 02-18-2010, 03:15 PM
