Results 1 to 8 of 8
    Jun 2017
    USA/CAN
    2.4 merc v6 carb swap
    Hi everyone,
    I recently picked up a new boat which is a hydrostream vegas with a 2.4 200, i did a compression test
    passenger side was 128 even across all 3
    driver side was 122 to 124
    Took it for a drive and it was holding 1800 rpms or so and would not plane pushed the choke for one second boom opened up went on plane and ran ok, i got into it once would only go to 5400 62mph with my 25P prop let off after about 10 seconds as i figured could be dirty carbs and didnt want to lean out a cylinder and blow it.
    There is a 2.4 bridgeport with two damaged cylinders for sale for a few hundred dollars and was thinking rather than rebuilding the stock carbs i could swap these on, Would there be any performance gains by doing so? Is the tuner the same or different? I cannot find a serial # anywhere on my engine to verify year. checked passenger side by the linkage and middle cylinder nothing anywhere.
    Thanks,
    TX......somewhere?
    carb kits are cheap.. really only need all new gaskets and good cleanin'.. look here for a build date.. on block half at base of number two cylinder.. its there, jus might be hard ta see... be 1/8" numbers, m/d/yr.
    oh yeah, havin' ta push tha key may be a fuel pump issue... its definitely a fuel delivery problem....
    Jun 2017
    USA/CAN
    Thank you, would there be any gain from using the bridgeport carbs?
    TX......somewhere?
    no.......... jmo
    Houston, TX
    You might double check what carbs you have now. If some bone head put on small ones, then maybe some gain. If you have wh 22 or 46, then stay with them.
    Jun 2017
    USA/CAN
    The existing ones have WH on the top left and 1374 5427c on the top right.
    Houston, TX
    Look real closely for where they hand stamped them
    TX......somewhere?
    if there is not a number "stamped" after tha WH you will need ta check size of mains to figure out what series WH they are.............
  1. 245 Carb Merc Parts Swap
    By ttopping in forum Technical Discussion
    Last Post: 01-13-2018, 09:16 PM
  2. Mercury Tech: Need Help! Carb Swap on '95 175 Merc
    By full monty in forum Technical Discussion
    Last Post: 08-27-2012, 07:59 AM
  3. Mercury Tech: Merc. carb swap
    By rdkvector in forum Technical Discussion
    Last Post: 02-06-2011, 09:55 AM
  4. Carb swap on 90 HP inline 6 Merc
    By rideordie in forum Technical Discussion
    Last Post: 02-01-2011, 04:42 PM
  5. 1987 Merc 220 EFI swap to CARB?
    By hawktuner in forum Technical Discussion
    Last Post: 04-05-2006, 09:21 PM
