Results 1 to 11 of 11
Thread: massive rich 200efi
09-22-2020, 12:20 AM #1Junior Member
- Jul 2016
- tucson Az
massive rich 200efi
looking for some help diagnosing my rich problem so rich it wont clean up with rpm had injectors done,adjusted tps to as low as it would go at idle .039v wot 7.36v, tried another ecu (digatal) known good from local boat shop ran the same if not richer tear your eyes in 2min.I am going to check resistance of iat and ect in morning could either one cause this much fuel? if i simply pinch fuel hose off to injectors,
with needle nose I can make it run near perfect any diagnostics would be greatly appreciated, Thank You in advance, Alan
09-22-2020, 05:08 AM #2
Tpi should be .250 with tan wires unplugged from port head . We had a 200 the other day really rich , turned out one of the o rings had torn that go from the vst to the fuel rail . The ones on the two aluminum tubes .
09-22-2020, 01:52 PM #36000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,527
- 427
- 63
- 433
- 450
Early efi used the 7.36v setting wot. sounds like super-hi fuel pressure.
09-22-2020, 11:48 PM #4Junior Member
- Jul 2016
- tucson Az
the tpi wont go any lower suspect I need a new one they are too exspensive@$600 retail anyone have a good one at a reasonable price ? thanks again
09-22-2020, 11:50 PM #5Junior Member
- Jul 2016
- tucson Az
I am going to check fuel pressure again tommorow Thank you
09-23-2020, 04:27 AM #6
tha 7.36 is real close.. its tha .039 that sucks.............
09-23-2020, 05:28 AM #7
Not sure this is your problem but if your pressure is high like mentioned, check little screen in the scheader valve. Need to open the 2 small philip screws.
09-23-2020, 06:31 AM #85000 RPM
- Aug 2007
- Gravenhurst, Ontario.
- 708
- 50
- 42
- 199
- 210
Check the enrichment circuit (yellow w/ Black). As a quick check, disconnect it. If the problem goes away you found the source of your problem. If there’s any power being bled off to that circuit your injectors are dumping fuel into the motor.
I had a very similar problem with a 260.....don’t ask how long it took to diagnose!!
09-23-2020, 08:57 AM #95000 RPM
- Feb 2013
- Northern Cal
- 190
- 18
- 37
Bad insulation or pinched wire on your injector harness wiring inside the plenum shorted to engine ground could being causing an injector to mis-operate and stay open . You can test the harness insulation real easy by separating the 4 pin round connector and checking the individual white , blue , & yellow injector coil wires to the plenum (engine ground) with a Multimeter set to ohms and it should read Meg ohms or very high thousands of ohms .
09-23-2020, 02:37 PM #10
.039v is low compared to what HF suggested .250
need to raise voltage itCheckmate 2002 Convincor 270 496 MAG-HO
90 21Skater w/300xs - sold
98 STV Euroski w/280 - sold
09-23-2020, 02:45 PM #11
wondered if he might have "misplaced" tha dot???.. don't think it would even attempt ta run at .039??? never tried/seen one that low........... jmo.
MYT - 'Massive Yet Tiny' Engine = 850 Hp
By BkWdsDrftr in forum Technical DiscussionReplies: 10Last Post: 07-23-2010, 02:08 PM -
Greg Cyranoski -g-train Rich Srnec Rich S
By Jim Morris in forum General Boating DiscussionReplies: 4Last Post: 10-06-2005, 06:11 AM -
Massive E-bay problem,HELP!
By Carter Powell in forum The Scream And Fly LoungeReplies: 10Last Post: 04-25-2004, 12:59 PM
