Results 1 to 8 of 8
Thread: oil injection
09-21-2020, 11:22 AM #1Junior Member
- Jun 2018
- San Diego ca
- 24
oil injection
Can you remove the oil injection on a 300XS,
09-21-2020, 11:53 AM #2
www.InjectorService.com
Call/Text - 204-326-0390
Tom120r thanked for this post
09-21-2020, 12:18 PM #3
But also, they don't use the old mechanical, gear-driven oil pump... so why?
InjectorService liked this post
09-22-2020, 11:11 AM #46000 RPM
- Aug 2015
- Southeast
- 1,070
- 134
- 80
- 48
- 615
Someone with better knowledge may chime in. But if I understand correctly, the fuel is injected directly into the combustion chamber, and oil is injected elsewhere for lubrication. If you premix, everything below the top of the piston will completely miss out on any lubrication since the fuel/oil mix is not traveling through the crankcase.
STV ProComp w/ 225 Promax
STV Procomp with 280
25 Liberator "The Battleship"
Blazer 650 Pro Tour
09-22-2020, 12:11 PM #5
09-22-2020, 12:26 PM #66000 RPM
- Aug 2015
- Southeast
- 1,070
- 134
- 80
- 48
- 615
David - WI liked this post
09-22-2020, 12:39 PM #7Junior Member
- Jun 2018
- San Diego ca
- 24
Thank you everyone for your comments, i want to keep the oil injection on my motor
i like not mixing the fuel
thanks
tom
09-22-2020, 03:22 PM #87000 RPM
- Feb 2005
- seattle
- 2,654
- 17
- 33
for example, the rod bearing caps on an oil mixed injection has a hole for collecting oil from the passing mixed fuel. the new oil system has no hole thus no oiling of the rod bearing. stay with the newer oil system.
crankcase injection- point in time of injection to fire injector?
By mrcrsr in forum Technical DiscussionReplies: 0Last Post: 08-08-2012, 06:38 AM -
point in time of fuel injection, has anyone played w/ different injection points?
By mrcrsr in forum Technical DiscussionReplies: 7Last Post: 01-28-2011, 08:21 AM -
How can you tell Laser injection from other 2.4 injection
By jowens in forum Technical DiscussionReplies: 10Last Post: 10-10-2009, 10:29 AM -
Direct Injection + Conventional Injection
By David in forum Technical DiscussionReplies: 3Last Post: 02-28-2006, 06:14 PM -
oil injection
By tomoad in forum Technical DiscussionReplies: 1Last Post: 09-19-2003, 03:43 PM
