Results 1 to 7 of 7
Thread: Head temp
    Sep 2017
    Ashland city tn
    Head temp
    lookin for temp sender that goes in stock location in the head. 2.5 200
    Its a carb motor , I think i need the 1 wire sensor? The 2 wire is the warning horn? I think thats right. Anyone got one in a blowed up motor or sumthin ? Thanks
    Feb 2005
    thibodaux la
    I have some the one wire is the heat alarm
    Sep 2017
    Ashland city tn
    Quote Originally Posted by levi ledet View Post
    So I need the 2 wire for guage?
    Feb 2005
    thibodaux la
    The one that goes on the port head has a few wires coming out of it
    Sep 2017
    Ashland city tn
    I have one that came off a efi motor that goes ecu but thats not right one , the carb one i belive has the tan wire and a ground
    Feb 2005
    thibodaux la
    The one off the efi will work
    Sep 2017
    Ashland city tn
    Ok thank you ill give it a try. I could have a bad guage idk. Do u have a for sure way to bench test with battery/power?
  1. Head temp OR water temp
    By Ted Stryker in forum Technical Discussion
    Last Post: 06-12-2007, 10:51 PM
  2. Temp sensor for OMC - water or head temp?
    By STV_Keith in forum Technical Discussion
    Last Post: 06-12-2006, 11:45 PM
  3. Head temp vs block temp
    By WATERWINGS in forum Technical Discussion
    Last Post: 06-27-2003, 04:57 PM
  4. Water temp Tee& head temp value?
    By Techno in forum Technical Discussion
    Last Post: 01-27-2002, 01:46 PM
