Results 1 to 6 of 6
Thread: Whale's tail
09-18-2020, 08:22 AM #1Member
- Jul 2018
- CORPUS CHRISTI TX
- 39
Whale's tail
Hey guy's,,,,a bud of mine gave me his whale's tail,,,,I have a 20ft flat bottom skiff with a 225 Evinrude,,,,,I have no problems with a hole shot,,,,,will the tail provide anything other assisting in a hole shot??
09-18-2020, 09:29 AM #2
sometimes you can stay on plane at a lower speed, it's highly dependent on motor height as to how it effects handling. If you're jacked up it won't be in the water at speed anyway...
Josh Peterson
09-18-2020, 09:51 AM #3Member
- Jul 2018
- CORPUS CHRISTI TX
- 39
Thanx Bud,,,,,I'm already running(cavitation plate) 3'' above the bottom of the boat so I don't see any advantage of installing the tale,,,,,I wonder if it would keep more water flowing into the lower unit water inlets,,,,,,I use my trim tabs now to crawl on plane over the flats now
,,,I appreciate your quick response
09-18-2020, 03:48 PM #4
It may still help you pop out quicker. I run the Bob's machine "true tracker" plate.
Josh Peterson
09-20-2020, 02:17 PM #5Member
- Jul 2018
- CORPUS CHRISTI TX
- 39
Thanx Nitro,,,since it was given to me & on top of that custom built(colored fiberglass) guess it's worth a try,,,,,I always like to ask before I drill anything
for other opinions
09-20-2020, 02:18 PM #6Member
- Jul 2018
- CORPUS CHRISTI TX
- 39
Sure 361.249.8722,,,,,call anytime
whale tail 15 + ship
By SUNKIST in forum Misc. Parts and AccessoriesReplies: 0Last Post: 03-16-2018, 09:00 AM -
Allison Whale Tail help
By hop2 in forum Technical DiscussionReplies: 9Last Post: 03-31-2009, 06:46 AM -
Whale-tail or Flop??
By ecg101 in forum Technical DiscussionReplies: 8Last Post: 03-08-2009, 03:48 AM -
Hydrafoil or Whale tail
By Commander in forum Technical DiscussionReplies: 3Last Post: 06-28-2001, 08:48 AM
