Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 36
    Jun 2020
    Edgewater MD
    2008 Checkmate Pulsare 2400 closed deck
    209 hours, new Hardin side mount billet shifter, new Livorsi NEMA 2K vantage view gauges, new Bimini included (not installed) new steering wheel, just serviced with new poppit valve, oil/fuel filter, water impeller, and powerhead gasket. Custom paint from factory, 2nd owner. Has 300xs, sea star hydraulic steering, CMC hydraulic 10” jackplate. Comes with trophy plus 25 prop and 26 tempest plus prop. GPS, Garmin chart plotter, 2019 sea lion trailer. Paint just buffed out and ceramic coated. New carpet. Has finished cuddy with porta potty. Runs 75 GPS, and cruises at 50. Turn key boat. Don’t need to sell, don’t really want to sell, but wife wants to go bigger. No brokers, no trades. $35000
  2. Likes Triple Digits II liked this post
    Dec 2017
    Lake Ashby, New Smyrna Beach FL
    OK I'll start-
    Motor year?
    Mid?
    Lower?
    Print outs for engine?
    Trailer brakes?
    Cover(s)?
    Please add pictures!
    Jun 2020
    Edgewater MD
    2008 pulsare
    2007 300xs
    20” torquemaster
    no trailer brakes
    yes mercury print out
    Dec 2017
    It sounds nice. Put up some pics
    Jun 2020
    Edgewater MD
ID:	473532Click image for larger version.
    Jun 2020
    Edgewater MD
ID:	473534Click image for larger version.
ID:	473535Click image for larger version.
    Jun 2020
    Edgewater MD
ID:	473538Click image for larger version.
    Attached Thumbnails Attached Thumbnails D21B58E3-8238-4C90-9A48-FFB922B8A284.jpg
  9. #8
    Jan 2020
    NY
    Wow!
  10. #9
    Jan 2005
    Rockwall, TX
    Does it have snap out carpet? Doesn't look like it does but thought I would ask.
    Never understood why boat manufactures used glue down carpet - short term cost savings for them but long term headaches for future owners as the moisture that the carpet holds leads to rot.
    Nice looking boat - interested if it has snap out carpet
  11. #10
    Jun 2020
    Edgewater MD
    No sir. Glue down. Solved the potential rot issue when I replaced the carpet. One cot of epoxy resin and good to go
  12. #11
    Jan 2005
    Rockwall, TX
    Quote Originally Posted by Pulse74 View Post
    Thanks - good move on the epoxy coat. Good luck with the sale. She is a nice looking boat for sure!
  13. #12
    Dec 2017
    How did you solve the carpet rot issue with a coat of epoxy? The carpet will still rot if it isn't dried out each and every time it gets soaked.
    The floor of every Checkmate is plywood base. If you mean you solved the potential wood rot issue, I don't think so. Coating it with epoxy won't save all the holes and openings and there are many. Not just in the floor.
    As far as the carpet rotting, if it gets wet... real wet like you get caught in a heavy rain storm just drain the boat well and put a few high velocity fans in it. The carpet will dry out pretty quick.
    rsscoggins- I've seen you comment on more than one CM ad worried about snap out carpet. CM never did this. But YOU can. If you want a Checkmate buy one! They are great boats. You are going to have to work on it. But you'd have to work on ANY boat. Accept that and make the best of what you pick.
  14. #13
    Jun 2020
    Edgewater MD
    Thanks for the lecture, my boat doesn’t get soaked. I keep it dry. The epoxy is waterproof. It’s simply a precautionary thing I did since I had the carpet out anyways. Whether you think it’s a solution or not. It’s piece of mind for me.
  15. #14
    Western Pennsylvania
    WOW... last time I saw that boat was new in local checkmate dealer located western PA New Kensington. I almost purchased it but wife didn't want the wild graphics(LOL)!
    90 21Skater w/300xs - sold
    98 STV Euroski w/280 - sold
  16. #15
    Dec 2017
    I'm not lecturing you eggshell. But you make my point. After you epoxied the floor was the perfect time to do snap in/out carpet.
  1. Checkmate pulsare 2400/mercury verado 300 pro
    By JUPITER PULSARE in forum Hulls larger than 20'
    Last Post: 10-22-2021, 01:02 PM
  2. Replies: 18
    Last Post: 11-03-2017, 03:08 PM
  3. Checkmate Pulsare 2400 BR and Pulsare 2400 BRX from last Sunday.
    By JUPITER PULSARE in forum General Boating Discussion
    Last Post: 10-02-2016, 08:48 AM
  4. 2012 Checkmate Pulsare 2400 Brx
    By faztbullet in forum Ebay Listings and Other Internet Listings
    Last Post: 06-24-2016, 06:54 AM
  5. Checkmate Pulsare 2400 or Superboat 24ft
    By swingray in forum General Boating Discussion
    Last Post: 05-28-2008, 01:57 PM
