Results 16 to 30 of 36
10-10-2020, 06:34 PM #16Junior Member
- Jun 2020
- Edgewater MD
- 13
Why point is that? I never said I wanted snap in carpet. Considering what I do for a living, if I wanted something other than carpet, I would have done it. Snap in carpet to me is just another way to create 20-30 more (access points) holes for water to enter the floor. And.....Eggshell? Really. Now we need to resort to name calling? If you can’t have a civil conversation, then why post on my thread? I don’t recall asking your opinion.
rsscoggins liked this post
10-10-2020, 06:44 PM #17
I had a 2003 Checkmate that had snap out carpet. Ordered it from the factory from the dealer in the Dakota’s. It didn’t have a fiberglass floor/liner but more of a rubber mat that was glued down and had snap in carpet on top of it.
I despise carpet in a boat - gets wet, dry rots, stinks and promotes rot. Snap out ain’t much better because the rubber backing comes off. I usually just take it out and leave it at home.
But I will continue to ask and inquire on boats that are listed here - this is a for sale forum and questions are expected before someone drives across the country to look at/buy a boat.
10-10-2020, 06:52 PM #18Junior Member
- Jun 2020
- Edgewater MD
- 13
Understand completely. I’ve never had carpet in a boat. Had snap in before but alway left it out. I did think about finishing the floor in gelcoat, then doing a seadek style floor. But it was mid season and didn’t really have the time to do it. If the boat doesn’t sell before winterization, then next spring I’ll do the floor like I wanted, add trim tabs and keep it another season. I also learned the wife likes the carpet, so that was good enough for me.
10-11-2020, 10:57 AM #19Junior Member
- Jun 2020
- Edgewater MD
- 13
Boat pending sale. Thanks
10-16-2020, 03:53 PM #20New Member
- Sep 2014
- Virginia
Think I saw you (or the buyer) rolling down 95S just south of Baltimore early one morning either this week or last...probably about 5am as I was on my way to work! LOL
Looked good on the trailer!
10-16-2020, 05:27 PM #216000 RPM
- Feb 2002
- Cudjoe Key FL
- 1,229
- 55
- 297
- 2738
- 3853
10-19-2020, 08:22 PM #22Member
- Oct 2020
- Amityville
- 48
You got anything left love the style been looking for one for a few years now
10-09-2021, 07:05 AM #23Junior Member
- Nov 2020
- Garden city
- 16
checkmate still available ?? call john please at 516-902-9090
10-10-2021, 06:05 AM #24Junior Member
- Nov 2020
- Garden city
- 16
please call john if available five one six 902-9090
10-10-2021, 11:51 AM #255000 RPM
- Sep 2019
- Lake Keowee, SC
- 243
- 25
- 62
I have a 2020 long deck 2400. It has a full cockpit liner and Dean told me that there was no wood any longer in the seat pedestals (mine are the low ones that are only about 3" high) nor any wood (just composite and fiberglass) in the floor liner. I have pictures of it being built but not with the liner turned upside down so they could have lied? Unfortunately, Checkmate puts a non wood access panel in the center of the floor so you have access to the fuel tank. This is screwed down and it is not sealed. So water could run down to the stringers and hull and the build pictures show the stringers are plywood and the hull sides are balsa core. So even with a composite liner, on a 2020, you are still at the mercy of Checkmate construction. So, like the issues that TraceF3 mentioned about the floor on the older models, still applies to how well the balsa cores, stringers and transom were sealed with glass, and how well were all the holes that they drilled into the wood sealed? I have a custom Aqua Traction stick down floor and have been fortunate so far not to get caught in a bad rainstorm. If I did, about 12 inches of the tank is exposed behind the back seat, but it would be difficult to get a fan to even blow under the floor to dry it out. Of course from what I have heard (never saw one) the new Caldwell Checkmates are wood free.
10-10-2021, 12:20 PM #26
The problem with mine was there was no hole in the tank box for water to drain out of. I'm assuming this was an oversight. I put a 1.25" hole in the bottom of the tank box when I rebuilt it so any water that gets in flows right in to the bilge. The tank box is above the bilge all the way to the recess that would be a ski locker or in my case a crawl through to the open bow. Any water that gets in there runs right to the back and gets bilged out. As long as your tank box has a drain hole you're golden
10-10-2021, 12:39 PM #275000 RPM
- Sep 2019
- Lake Keowee, SC
- 243
- 25
- 62
10-10-2021, 12:52 PM #28
The tabs do not hold the tank up. They keep the tank still when the foam is poured. If you had a full tank of fuel and jumped a big wake you could pull the tabs loose. The welds would be stronger than the metal.
Yes you should have an inch or so under the tank. Mine is sitting on rubber blocks that are fastened to the tank with 5200 (waterproof seal) and I was careful when I poured the foam. Water can get in and water can get out now.
Squeeze down in your bilge and feel the bottom of that rear bulkhead. There should be a hole to drain the box. If you reach far enough you will be able to feel the opening where the bilge is below the tank.\\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\///
10-10-2021, 12:53 PM #29
And is that your boat in the picture? Sure isn't wood free......
10-10-2021, 03:08 PM #305000 RPM
- Sep 2019
- Lake Keowee, SC
- 243
- 25
- 62
Yes that is my boat, and it is not wood free, it was the 2nd last boat built in Bucyrus. I mentioned that the new Caldwell Checkmates built in NC are supposedly wood free. Mine has no wood on the floor or seat pedestals or the liner, but as you can see the stringers, transom, knees and cross supports as well as the balsa core are wood. I have felt the space under the tank and on the picture you can see a small space under the center of the tank box. If the tank sits on rubber supports on the angled part any water could drain out. If that area is foamed, it could hold water I would think.
Checkmate pulsare 2400/mercury verado 300 pro
By JUPITER PULSARE in forum Hulls larger than 20'Replies: 28Last Post: 10-22-2021, 01:02 PM -
2008/12 24' Checkmate Pulsare Closed Deck 2012 300XS 2017 Trailer
By mragu in forum Hulls larger than 20'Replies: 18Last Post: 11-03-2017, 03:08 PM -
Checkmate Pulsare 2400 BR and Pulsare 2400 BRX from last Sunday.
By JUPITER PULSARE in forum General Boating DiscussionReplies: 19Last Post: 10-02-2016, 08:48 AM -
2012 Checkmate Pulsare 2400 Brx
By faztbullet in forum Ebay Listings and Other Internet ListingsReplies: 1Last Post: 06-24-2016, 06:54 AM -
Checkmate Pulsare 2400 or Superboat 24ft
By swingray in forum General Boating DiscussionReplies: 9Last Post: 05-28-2008, 01:57 PM
