Results 1 to 4 of 4
09-15-2020, 04:31 PM #1Junior Member
- Aug 2020
- Evian - France
- 11
Gearcase ratio 300X for a skater 21
Hi everybody,
Does anyone have an idea of the better gearcase ratio on a skater 21 single 300 R set up ? (300R yeah sorry, i miss the tittle... not 300X...)
1.62 or 1.75 ?
Thank you for your answer !Last edited by LeonardG; 09-15-2020 at 05:14 PM.
09-16-2020, 12:58 PM #2
Had a 22 Liberator with a 300r. It was set up with the 1.75 gear ratio. Was running a 34 pitch 5 blade Cleaver 15.25 inches in diameter. Boat ran 111 at 6300 rpm. Wasnt a lot of prop choices available. Randy has run the same combination with a 1.62. Ran about the same speed, with less prop, but acceleration was slower.
Would think a 1.62 would be better. Would give you more prop choices to dial in your combination. With the 1.75 gear, I could see you at 36 pitch or more, because you have to run these gearcases high to get the speed out of them. Once you get above 36 pitch their are not many choices unless you go custom, like DeWald, or Hering.
09-16-2020, 01:40 PM #3Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,644
- 606
- 923
- 1698
- 7151
- 3 Post(s)
The 1.60 ratio has proven to be faster on all of the test that I have seen and were posted from Mercury.
09-16-2020, 03:07 PM #4Junior Member
- Aug 2020
- Evian - France
- 11
Thank you for your answer.
Why does Nick on mercury racing forum (here) is advising me a 1.75 :/
I posted here because i think boaters are > than ingeneers or sellers...
It really need to be clear in my mind, i want my 21 skater to go 100 mph and don't miss it and be easy to ride to.
Possible to tell if Merc 2.5 liter gearcase is 1.87 or 2.00 gear ratio from outside?
By Bumblebeeman in forum Technical DiscussionReplies: 15Last Post: 10-12-2018, 06:04 PM -
WTB CLE gearcase or sportmaster for 2.5 1:87 ratio
By 2.5-21 in forum Parts WantedReplies: 11Last Post: 09-01-2013, 04:47 PM -
videos of gearcase and rear of 300x cowl on the skater
By mrcrsr in forum General Boating DiscussionReplies: 25Last Post: 12-13-2011, 07:49 PM
