Results 1 to 4 of 4
    Nov 2003
    old hickory,tn
    2.5 Drag egt readings.
    Running a 2.5 drag with original a6 box and low compression heads. What's the best way to keep the heat at a lower temperature when cruising around 5to 6000rpms?
    TX......somewhere?
    you've got to CONTROL water exit...... may jus have ta do some experimentin'............
    The A6 has a Lean spot purposely programmed in it at 5000/6000 RPM. That is not the box you want for Cruising. Get you a 11350 digital with a A48 Chip and a 39 psi regulator Its a Drag Curve but its a richer curve all the way through the program. The A6 at 5000/6000K for extended periods of time will lean Burn your pistons.
  4. Likes bohemian609, Capt.Insane-o, JAFFA liked this post
    TX......somewhere?
    Quote Originally Posted by bohemian609 View Post
    guess i can't fckin' read this early in tha mornin'........................................
  1. Help on DDT readings 04 -280 ROS
    By kellytheaker in forum Technical Discussion
    Last Post: 03-23-2020, 01:14 PM
  2. Ddt Readings-little Help Please??
    By bill mason in forum Technical Discussion
    Last Post: 04-16-2007, 06:24 AM
  3. 2.5 260 egt readings
    By YELLOWSS in forum Technical Discussion
    Last Post: 09-30-2005, 08:28 PM
  4. EGT Readings.....
    By Jrocket in forum Technical Discussion
    Last Post: 09-09-2001, 11:19 PM
  5. 2.5 EFI EGT readings at WOT
    By Frequent Flyer in forum General Boating Discussion
    Last Post: 04-30-2001, 07:25 PM
