Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 32
    Miami,Fl
    Need some advice voles
    Got a bad infestation of voles everyday there are more holes I have tried a few things and no avail. One of dam things took a mouse trap any suggestions. Thanks Rick
    The great corn desert of Iowa
    Crimson Tide?
    1971 Sidewinder 14 SS w Johnson 90 v-4
    1959 Texas Maid Falcon w Mercury Mark 35A
    1981 Sylvan Sportster w Johnson 85 v-4
    2006 Harris pontoon with a Yamaha 90
    1969 Sunfish sailboat
  3. Likes CDave liked this post
    Jun 2018
    Floating around
    Aerate the lawn with an aerator you can usually rent them for a day and pour castor oil with a bit of Murphy’s oil soap in all the holes. Should send em packing
  5. Thanks delawarerick thanked for this post
    Ft. Lauderdale, Fl
    leave out some cat food to attract the neighborhood cats to your property
  7. Likes delawarerick, Forkin' Crazy, JPEROG liked this post
    NE Louisiana
  9. Likes LakeFever, CDave, Glasstream15, keefallan liked this post
  10. #6
    Feb 2011
    HUDSON, FLORIDA
    Moth balls
  11. #7
    Miami,Fl
    Appreciate the advice these things are multiplying now I got raccoon prints digging by the holes. I ordered castor oil and a sprayer I have been dropping chewing gum in the holes and they just go to another area. So far I have had roof rats the gas company left a hole around the pipe caught them closed around the pipe, had a mouse got him in a trap, a raccoon tore the screen out of the soffit vent and tore the attic up got him out and repaired the hole. I have a blind veteran next door and everything is over grown and I check on him and help him with problems but the yard is above me it's a jungle. I have a dog and poison is out of the question any light anyone can shed is appreciated houses too close to shoot em I have a single shot 22 remington with a long barrel can dot and i can only wish. thanks
  12. #8
    Nov 2001
    Lake Charles, Louisiana
    Maybe this would lure them out of their holes so you could shoot them.
    https://www.amazon.com/Caddyshack-Go...0369706&sr=8-2
    93 STV Mod VP/MERC 2.5 200
    Proverbs 4:18-20
    -- John F. Kennedy 1962
  13. Likes delawarerick, Forkin' Crazy liked this post
  14. #9
    Jun 2018
    Floating around
    I’m tapped that’s all I know. Had em once years ago did the oil trick and they were gone that year. Plenty of cats around though so maybe that had something to do with it
  15. Thanks delawarerick thanked for this post
  16. #10
    Lindenhurst, NY
  17. Likes XstreamVking liked this post
  18. #11
    Quote Originally Posted by delawarerick View Post
    ...now that the weather will be a bit cooler, ask around, or print some flyers, asking for volunteers to all get together on a saturday, to attack & cleanup the veteran neighbors complete yard. would suggest to plan to do it on a saturday, just before your bulk trash pickup day. O.K. this with the veteran first. then at your house, buy & install the long white perforated plastic(sometimes there white aluminum) soffit grills that homo depot or lowes sells. i screwed mine up with short little hex head screws that i zipped in with a battery drill with a little socket that fits the hex head. i spray painted them white on a big piece of cardboard the day before.
  19. Likes keefallan liked this post
  20. #12
    ...this is what the soffit grills, or screens, look like. they could be metal or plastic. each section is 10' long. they really work & look good. they can be flipped on either side depending how they fit your soffit best...
  21. #13
    ...those screens come with mounting holes in them usually, they just are'nt in that picture. these are the short type hex head screws i used to screw mine into my existing wood soffit trim that was already up there on my florida house. this picture makes them look really big, they are not, they are quite small.
  22. #14
    ...when installing the above screen sections, overlap them ever so slightly & thats where you put some screws...at the overlap. don't butt end them. you can also simply install these new screen/grills right over the top of your existing original mesh screens. no need to tear out the old stuff. a helper at the bottom of the ladder, handing you things, really makes this job fast & easy.
  23. #15
    ...rick, do you live on a canal, or on the water?
  1. My first 2.4 , need advice
    By LOSTINJ in forum Technical Discussion
    Last Post: 05-29-2019, 07:41 PM
  2. need advice on a sbc 400
    By seasquirrel72 in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 06-05-2010, 07:55 PM
  3. Advice
    By too late in forum The Scream And Fly Lounge
    Last Post: 11-12-2009, 09:44 AM
  4. 24 cat need advice
    By 23 MTR in forum General Boating Discussion
    Last Post: 03-04-2008, 06:43 PM
  5. Need some advice bad
    By 22' Pacanga in forum Props, Setup, and Rigging
    Last Post: 09-28-2006, 11:58 PM
