Results 1 to 15 of 21
    Jul 2007
    Hamilton Ohio
    Adding low water fitting to 2005 XR6 Lower Unit
    What is the recommended thread size (NPT) for adding a low water pickup fitting on the suction side of the L/Unit water chamber ?
    Thx
    Gary
    Growing old is inevitable, growing up is optional.......
    Jul 2002
    FT WORTH, TEXAS
    lwp? you mean a cone job?? its 1/2 npt ! years ago when i was doing only lower unit rebuilds and cone jobs now and then i started doing a lot of coning and had much better luck getting the cooling i was needing using two hose's instead of one jm.02
  3. Likes nitro_rat, tux974 liked this post
    Houston, TX
    Quote Originally Posted by TEXAS20225 View Post
    One hose on each side really makes a difference, Tex? What did you run for hoses and fittings?
    Jul 2012
    Lufkin, Texas
    Quote Originally Posted by rgsauger View Post
    Yes, and also according to John Marles from his cooling mods article:
    Quote Originally Posted by us1 View Post
    Nose cones seem to need two-½ inch hoses from the cone to the pump to really make good flow and pressure.
    Josh Peterson
  6. Thanks rgsauger thanked for this post
    Jul 2002
    FT WORTH, TEXAS
    i always used Bobs stuff when it was still Bobs i had account with them they had a very good cone in my opinion i used hard copper tube of the ac variety as it was bigger then water copper tube so more water! and then i fiberglassed them in they looked cool after i stopped going to all that trouble i used hose and fittings provided by Bob and bought stainless braid for hose cover but i always welded these guys up more then anyone i knew but not solid i liked to pour epoxy in the gap in between housing and cone so no void was left just in case. im not sure how many i did it was quite a few i shipped them all over the US for several years but i quit after i started building more and more motors shucks i could build two motorswhile i was messing with that one gear case
  8. Thanks rgsauger thanked for this post
    Likes nitro_rat, rgsauger liked this post
    Jul 2004
    Connecticut
    Quote Originally Posted by Liberator*21 View Post
    What is the recommended thread size (NPT) for adding a low water pickup fitting on the suction side of the L/Unit water chamber ? Thx
    Where did you find a 2005 XR6 lower unit?
    Jul 2007
    Hamilton Ohio
    FaceBook Market Place.
    Gary
    Jul 2007
    Hamilton Ohio
    -12 AN Fitting is in. Thanks all.
    Gary
    Minneapolis MN
    What are you guys doing with the drain fitting on a much older case? About to weld the cone on and not sure what to do with the drain.
    TX......somewhere?
    jus a question.. where is tha "other end" that feeds tha pump?
  14. #11
    TX......somewhere?
    Quote Originally Posted by tnelsmn View Post
    ya gotta "french" it in with a very short piece (can be long ta start and cut ta fit your body work) of tubing welded and/or epoxied to tha case.....
  15. Thanks tnelsmn thanked for this post
  16. #12
    Jul 2007
    Hamilton Ohio
    This is a work in progress project. I've yet to machine up a water pickup for the transom, it will be similar to a Bob's unit except better. I would have gone with a low water pickup nose cone but my 15" mid won't allow it, it would interfere with the clamp/jackplate.
    Gary
    TX......somewhere?
    gottcha.. so transom mounted inlet?.. tha "open" holes thru me off a bit..............
  18. #14
    Jul 2002
    FT WORTH, TEXAS
    looks like a lot of work on a nonratcheting case not sure of what the cone will do for you with it setting low enough in the water for the side inlets to work
  19. #15
    Jul 2007
    Hamilton Ohio
    Setup yet to be determined, winter project. Lotta work....yes, but I'm retired so time/work is not a factor here, it's all play..........
    Gary
  1. Replies: 5
    Last Post: 08-04-2010, 07:40 PM
  2. Water Press fitting
    By unclebuck134 in forum Technical Discussion
    Last Post: 02-16-2010, 09:52 PM
  3. Mercury Tech: water pressure fitting
    By Aggressive Machines in forum Technical Discussion
    Last Post: 10-13-2009, 07:25 AM
  4. Water Pressure Fitting
    Last Post: 08-17-2009, 03:53 PM
