Results 1 to 4 of 4
    Nov 2008
    martinsburg, wv
    Crossflow v4 fuel question
    hey guys, my 94 115 crossflow has the plastic style fuel rail that is obsolete. Is there any issues with rigging it up with a 4 way barb fitting like this? My finger is pointing to the main fuel line - does it need to be top fill like the plastic rail, or is the pump capable of keeping the lines fuel with any orientation?
    Jan 2015
    As long as you did not go smaller then OEM diameters, it should be OK. If floats are set right and needle valves are working, the bowls will fill up and that line should keep them full.
    Jan 2015
    If that does not work properly for you, (it should work) there are a few used ones on ebay:
    https://www.ebay.com/sch/i.html?_fro...94312&_sacat=0
    Nov 2008
    martinsburg, wv
    Everything is 5/16. So should be ok?
  1. OMC Tech: Crossflow Fuel Injection
    By BoatMedic in forum Technical Discussion
    Last Post: 11-09-2015, 07:16 AM
  2. OMC Tech: crossflow fuel mix discrepancy?
    By pcrussell50 in forum Technical Discussion
    Last Post: 11-05-2009, 11:13 PM
  3. v4 crossflow fuel pressure
    By richard1506 in forum Technical Discussion
    Last Post: 10-06-2009, 12:26 PM
  4. 175 crossflow fuel?
    By bennyb in forum Technical Discussion
    Last Post: 04-13-2009, 07:01 PM
  5. Fuel System Design OMC V6 RS Crossflow
    By RogerH in forum Technical Discussion
    Last Post: 10-31-2008, 06:25 PM
