Results 16 to 30 of 32
09-10-2020, 10:28 AM #165000 RPM
- Jul 2015
- Georgia
- 133
09-10-2020, 10:44 AM #175000 RPM
- Nov 2008
- martinsburg, wv
- 398
09-10-2020, 12:39 PM #185000 RPM
- Jul 2015
- Georgia
- 133
09-10-2020, 01:24 PM #19Scream And Fly VIP
- Sep 2011
- maryland
- 1,560
- 262
- 178
- 1709
- 1309
Ok. you should have 326504/505 for your year motor. The compression for them should be 120. The other head is is off of a 1988 110 crossflow. I dont know if thats a low compression head for that motor. The 88 and 90hp for that same year have a different head number. Now whether its a higher compression head than the 110, I dunno. Actually, I just checked again, the 88 and 90 use the same heads that your motor is supposed to have. Since it came off of a 110 and not a 115, it most likely is a low comp head and thats why it was rated at 110 hp and not 115. The 110 was a better fit back then when there was a 120 looper real close in power. So, they detuned the 115 with poor heads.....is my best guess.
09-10-2020, 01:27 PM #20Scream And Fly VIP
- Sep 2011
- maryland
- 1,560
- 262
- 178
- 1709
- 1309
I just checked and found that the 1984 115 had the same heads that you do(the 504/505 heads). SO, it looks like they did in fact put on a low compression head for the 110..........I never knew that. I have been preaching that the v4's make 120 compression with tub heads(and they do), just not with the tub heads that 329538 part number. Swap out the head and your problem should be solved as to the compression mystery.
Powerabout, you ever seen a set of those 110 heads before? Is it a deeper head or more of a lip on it than the standard heads?Last edited by keefallan; 09-10-2020 at 01:31 PM.
LakeFever liked this post
09-10-2020, 01:31 PM #21
There it is, nice work keefallan
keefallan thanked for this post
09-10-2020, 01:37 PM #22Scream And Fly VIP
- Sep 2011
- maryland
- 1,560
- 262
- 178
- 1709
- 1309
I love talking about the crossflows Lakefever...........and I like learning about them just as much.
09-10-2020, 01:42 PM #23
I’m going to run 504/505 heads on my 79 140. Same heads my 83 115 had and that motor ran strong and hard just over 6000RPM and ran there every time out for years and years on whatever marina gas I happened to be near and on any tcw3 oil I could get at the cheapest price I could find. Walmart brand etc. Never had a blip of trouble.
going for new reeds, square up the ports a bit and stuff it on my vandal. Should be a lot of funHydrostream dreamin
09-10-2020, 01:45 PM #24Scream And Fly VIP
- Sep 2011
- maryland
- 1,560
- 262
- 178
- 1709
- 1309
09-10-2020, 02:17 PM #25Scream And Fly VIP
- Sep 2011
- maryland
- 1,560
- 262
- 178
- 1709
- 1309
09-10-2020, 06:52 PM #26Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
the 110 head is a low comp version
09-10-2020, 06:56 PM #275000 RPM
- Jul 2015
- Georgia
- 133
09-18-2020, 09:44 AM #28
keefallan liked this post
09-18-2020, 10:55 AM #29Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
09-18-2020, 01:29 PM #30Scream And Fly VIP
- Sep 2011
- maryland
- 1,560
- 262
- 178
- 1709
- 1309
Fmp, why are there so many haters of wisecos? Is it because of the amount of movement of the forged piston itself? I remember purchasing a 150 crossflow powerhead, and it had .30 wisecos in it. I threw on a set of 872/873 heads and did a compression check to just see what the tight heads would for me. I got excited. So, when I built a new powerhead with cast pistons and those tight heads, I was disappointed. I saw 5 or 10 less. I have another story with that 115 I keep talking about. It was messed up by the machinist. I bought it with a bad hole. The piston kissed the wall and left a bunch of aluminum on the side. But, it all cleaned up, minus a little tiny catch with a fingernail. I knew it would clean up with a .010 boring. The others were great after honing(before too, but I was installing rings anyways). When I got the block back, he bored the opposite caddycorner hole out, realized it, and resleeved it, and then punched out the needed hole to .064. So, I see 145 in the cast piston holes(90 in the broken ring hole), and 160 in the wiseco hole!! I didnt know if it was from the amount of air being moved by the huge piston, or the forged design of the wiseco. But compression went way up. I didnt have anything I could do about it at the time, and I got 7 years out of it. I ran it all day yesterday without a hitch. Cant wait to build the new p-head. I have only seen good things from wisecos. I just havent bought a set yet, because my kits never had them in it. When I tear this bad p-head down, I will compare the piston tops to decide what I am gonna do for my next build.....especially if compression goes up too. But I cant 100 percent confirm it. But my 2 experiences with wisecos have had bigger compression numbers.
FMP liked this post
76 v-4 crossflow max compression
By JuicedHallett in forum Technical DiscussionReplies: 14Last Post: 10-31-2012, 07:06 AM -
v4 crossflow compression
By evilrude 1 in forum Technical DiscussionReplies: 29Last Post: 03-30-2012, 09:03 AM -
OMC Tech: crossflow compression
By wanagofass in forum Technical DiscussionReplies: 1Last Post: 05-26-2011, 10:51 PM -
Crossflow Compression??
By Jay R. in forum Technical DiscussionReplies: 18Last Post: 07-31-2009, 04:53 PM -
OMC Crossflow compression
By Lockjaw in forum Technical DiscussionReplies: 1Last Post: 11-27-2005, 10:57 PM
