Results 1 to 1 of 1
    Jun 2011
    Greenville, NC
    Prop hub question
    Boat is a 88 Formula F242SS, 330HP BBC motor with a Bravo 1. It has a 21P old Mirage Prop (no PVS) with a rubber hub.
    So I spun the hub in my prop last weekend. When I pressed the old hub out, I noticed the square pattern the rubber hub was pressed into looked a lot like the Flo Torq hub pattern. So I happen to have a flo torq II hub insert laying around, I dropped it into the prop and it fit perfectly.
    So the question is - do I need to bother having a new rubber hub pressed in, or can I just use the Flo-Torq hub?
    Feb 2005
    seattle
    i've done to 4-5 props. no problem but torque the prop correctly. 125 for the rubber type props and the small sq tork hubs . 40 for large shaft torq II hubs
  1. Prop question
    By jp2dunk in forum Technical Discussion
    Last Post: 08-11-2018, 09:37 PM
  2. OMC Tech: omc prop question
    By camaroguy67 in forum Technical Discussion
    Last Post: 03-13-2009, 02:15 PM
  3. prop question
    By skipe in forum Technical Discussion
    Last Post: 05-27-2007, 06:56 PM
  4. prop question
    By CLIMATEMASTER in forum Props, Setup, and Rigging
    Last Post: 08-22-2006, 11:40 AM
  5. Prop hub question
    By tombrown in forum Technical Discussion
    Last Post: 08-23-2001, 11:47 AM
